Old 06-30-2010, 07:36 PM   #1
Exclamation
Aude Timer Install Issue
I removed an old intermatic timer because the display for some reason had become unreadable. I bought an Aube T1032-3w but want to install it as just a single pole switch. I have three wires in the box, yellow which I think goes to the porch light, a red wire and 2 wire nutted white wires.
The switch has 3 black wires labeled C, 1 and 2. I'm tired, it's been a long work day would some electrical genius point out how I should wire this.
Many Thanks.
Jimmy G is offline   Reply With Quote
Old 06-30-2010, 10:08 PM   #2
Electrical Contractor
From what I read, connect the c and wire #2 to the incoming power, and connect wire #1 to the load.
http://www.aubetech.com/manuel/2/TI032.pdf
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-30-2010, 11:32 PM   #3
Thanks jbfan, but I need a little more info since I'm new at this. Am I correct that the load wire is the yellow wire that goes to the light? so the c and 2 wire go to the red wire incoming power.?
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Oil tank whistle valve install toxic oreo HVAC 10 12-27-2009 09:42 PM
sprinkler timer location issue the carpenter Landscaping & Lawn Care 1 09-07-2009 04:50 PM
Is this how I wire a 240v timer? Piedmont Electrical 3 04-23-2009 10:16 PM
install sink in granite after basic install? damstenger Remodeling 3 02-06-2009 07:37 PM
