Aube T1033 Installation Help, Please - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 12:46 PM   #1
Hi all, thanks for being here.
I need help figuring out how to wire up an Aube T1033. I've attached a .pdf depicting my existing switch box. I want to replace the right hand switch with the T1033. The existing wiring is more complicated than I expected.
Aube's T1033 installation manual is here: http://www.aubetech.com/manuel/2/TI033.pdf
Thanks in advance for any insight you can provide.
-- Bill
etihw.llib is offline   Reply With Quote
Old 01-31-2011, 01:06 AM   #2
You need a TI-0723W 3-way switch
Something is wrong with your diagram. You describe a "3-way" setup where two different switches control a single load. For a functional three-way with standard, dumb switches, both switches must have three connectors. On each switch, one of the connectors is labeled "common" and might have a different color screw. The switches channel "hot" onto one of two travelling wires - when the switches put hot on the same wire, the load is energized.
If you have a standard 3-way setup, then you have the wrong Aube part. The Aube 1033 does not support a remote switch.
The appropriate Aube part for a a "3-way" application is the TI072-3W. This switch must be installed in the box which contains both the supply hot/neutral and also the load wires. Your diagram doesn't show what goes to which boxes...
The Aube allows you to use a single pole switch in the remote location; if you want to re-use an existing 3-way remote switch, you jumper common with one output. It's possible you could replace your left-side switch with the Aube TI072.
JDS13 is offline   Reply With Quote
Tags
aube , switch , timer
3-way switch installation - TI070-3W Aube Local Dimwit Electrical 15 05-07-2011 10:33 AM
Installation of Aube TI034-3W aprangus Electrical 3 09-06-2010 08:41 AM
Aube ti034-3w lightswitch wiring Local Dimwit Electrical 7 02-25-2009 08:14 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
