Attice Fan Cutting Out - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 03:18 PM   #1
Attice Fan cutting out
I have an attic fan that during the summer months, it will stop on its own. I'm not sure if it is equiped with a thermal cut out or mabey if the attic gets so pressurized that it makes the fan cut out? But either way it will cut out for a few minutes and then start back up.
swoop is offline   Reply With Quote
Old 05-10-2010, 05:03 PM   #2
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Sounds like it is overheating or the thermostat is set too high! Does it have a thermostat next to it? If it does check what it is set at. Also, if you don't have enough venting to supply air at the same rate or better than the fans is pushing it out it can cause it to overheat.
sparks1up is offline   Reply With Quote
Old 05-10-2010, 05:27 PM   #3
Bad bearings will cause the motor to overheat and have its thermal cutout switch embedded in the windings cycle on and off, even while the 'stat continues to ask for cooling.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Cutting into Cast-Iron waste pipe. dOe Plumbing 4 03-29-2010 07:09 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
