Attic Wiring Over Joists - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 11:56 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Attic wiring over joists
Was reading the below thread that talked about protecting wiring in an attic and I think we have an "ut oh" that needs to be fixed.
Our wiring runs perpendicular to the joists all over the attic. Currently its not stapled over the joists although I can do that if necessary.
The attic is accessible by permanent pull down stairs but we do not use the attic space for storage.
If this is the case, do we have to staple or cover the wires that are there to protect them?
Again if we are not using the attic for storage do we have to cover the wires within 6 feet and does the 6 foot rule apply to overhead wiring up there or just the wiring on the ground.
History -we flooded and are rebuilding the lower half and will have an inspection but supposedly they will not back check us for items unless they are considered a safety issue and I can see this as being one so want to be up to date.
Romex wires in attic questions
forcedreno2012 is offline   Reply With Quote
Old 04-19-2013, 12:57 PM   #2
Licensed electrician
Rewards Points: 1,610
When was the wiring installed? The code has changed over the years. Why do you think this is an issue?
Old 04-19-2013, 09:22 PM   #3
Rewards Points: 616
Jim we are rebuilding after a hurricane flood.
The wiring itself was done in 1991 and is 12/2 through out the house and is in really good condition and was wired by a master (I would pay to be able to twist wires like the dude that did it originally) ....its the newer added later stuff we had to rip out and correct.
When you rebuild they are checking to make sure that the house is safe. They will be up in the attic inspecting the new AC and I want to make sure I don't get pinged on something else if its a big deal.
Right now there is spaghetti wires all over the place that are not secured.
Building Knee Walls in the Attic Jimmybrp Building & Construction 12 12-23-2011 01:22 PM
Ideas on reinforcing attic joists PhaTea Building & Construction 22 12-07-2011 09:41 PM
Laying attic floor: what should I do about exposed wiring? scool Electrical 6 11-11-2010 11:23 AM
Wiring Protection for Accessible Attic BillyDIY Electrical 6 11-05-2009 08:44 PM
Running New Wiring to Attic PCC Electrical 12 02-08-2008 04:09 PM
