Attic Wiring To Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 05:03 PM   #1
attic wiring to detached garage
I would like to run either cable or wire (3#6, 1#8) through the attic to the new detached garage. Are these required to be in conduit? Can they be run loose across the tops of the ceiling joists?
del jones is offline   Reply With Quote
Old 03-12-2010, 05:09 PM   #2
Master Electrician
Rewards Points: 3,698
A cable asembly(nm),(ser) CAN BE BUT NOT INDIVIDUAL conductors.
Through the attic to a detached garage?
brric is offline   Reply With Quote
Old 03-12-2010, 10:50 PM   #3
Rewards Points: 1,016
Is there a breezeway or similar structure to the 'detached' garage?
Old 03-13-2010, 12:52 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you lost me on this one too!
plummen is offline   Reply With Quote
Old 03-13-2010, 03:48 AM   #5
" Euro " electrician
frenchelectrican's Avatar
You did not give us very clear details however.,
Let say you are plan to run this in underground set up with conduit the conduit you will need THHN/THWN conductors in conduit.
or run the 16mmX3 {6-3} NM cable until just before you run it outside you will have to make a junction box to translated from NM to THHN/THWN conduit from there you can run it to the detached garage.
For the junction box I really strongly recomened that you get 6X6X4 box size due you will have little more room to work around to hook it up properly.
BTW the conduit it will have to be buried 450mm { 18 inches } deep if not in conduit then it will bump more deeper to 600mm { 24 inches }
Merci,Marc
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 10:55 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 08:31 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
