Attic Lights - Copper Wire But No Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 12:22 PM   #1
Attic lights - Copper wire but no ground
I have an older house and decided to replace attic lights yesterday. It has the metal boxes and older 2 conductor copper wire with no ground connected to a switch on a different floor.
I am considering two options:
- Installing a GFCI type receptacle at the first box in the feed.
- Providing ground from a nearby box (attic fan) that is grounded properly.
Could you please provide the feedback?
Igorr is offline   Reply With Quote
Old 11-20-2012, 06:03 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You can not use a ground from another circuit.
If you are replacing lights on existing ungrounded lighting outlets, you do not have to add a ground.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-20-2012, 06:36 PM   #3
rjniles, thank you for the reply!
I am also replacing wires and the boxes. And the new lighting fixture comes with the ground wire.
Installing a GFCI type receptacle at the first box in the feed will do the job, right?
Old 11-20-2012, 08:06 PM   #4
Licensed electrician
Rewards Points: 1,296
A GFI does not provide a ground.
The ground either comes in the circuit wiring or with a metallic raceway.
Old 11-20-2012, 08:07 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Also, you cannot extend an ungrounded circuit...
The Following User Says Thank You to stickboy1375 For This Useful Post:
frenchelectrican (11-20-2012)
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 06:28 PM
Service wire thru attic Poot Electrical 23 02-10-2009 08:17 AM
