Attic Light Switch Location - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 09:29 AM   #1
Attic light switch location
I saw your photos and I have a similar wiring situation in my attic with Romex running up a joist to a light switch box and a duplex receptical, both in metal boxes. The wiring is secured with insulated staples. Did you get confirmation that this is OK? How far from the opening to the stair well is it permissable to have a switch fasrened to a joist? It is convenient to have it located within reach to turn on the lights while standing on the stairs.
Thanks,
Art Lewis
artlewis is offline   Reply With Quote
Old 09-02-2010, 09:43 AM   #2
Licensed electrician
Rewards Points: 1,884
The light switch for an attic is required to be located near the entrance to the space. Either on the wall before entering or within reach after entering the attic would work.
Old 09-02-2010, 10:32 AM   #3
Thanks! It is within reach.
Is it necessary to protect Romex running up a joist if it is stapled securely with insulated staples?
Old 09-02-2010, 10:34 AM   #4
If you mean up the side of a truss web I think you will be fine.
Old 09-02-2010, 01:39 PM   #5
Thanks! It looks exactly like the picture above with the square box with a duplex receptical and switch and runs of # 12 Romex to it. I could nail 2 X 2 fir strips on either side of the Romex if required to give it more protection.
Light switch failure help!! metalrex Electrical 22 02-04-2010 09:13 PM
Add new light and switch to a switch loop UncertainSparky Electrical 4 01-24-2010 08:58 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
