Attic Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 07:45 PM   #1
jburd964's Avatar
Rewards Points: 166
Attic Light Switch
Is there a special attic light switch that can turn light on when drop ladder opens?
jburd964 is offline   Reply With Quote
Old 11-17-2011, 07:51 PM   #2
Boston Fan, get over it
Toofarfromfenwa's Avatar
Yes, it's called a doorway switch.
Something like this should do the trick.
http://www.grainger.com/Grainger/THO...t-Switch-4YF22
Toofarfromfenwa is offline   Reply With Quote
Old 11-17-2011, 07:53 PM   #3
Missouri Bound's Avatar
WEll....indirectly you could use one of the X 10 devices with a motion sensor. Other than that there are contacts which could switch a low voltage circuit. It certainly can be done.
Old 11-17-2011, 07:54 PM   #4
Rewards Points: 756
How about a switch that will turn the light off when the stairs go up?
Seriously, check out something like this:
http://www.pegasuslighting.com/door-...ign=googlebase
You could mount it on the side of the access opening so that the plunger opens when you open the door.
AandPDan is online now   Reply With Quote
Old 11-17-2011, 08:00 PM   #5
Yes, you could use an occupancy sensor. But, the most simple would be one of the door jamb switches that has been linked to.
Old 11-17-2011, 09:20 PM   #6
jburd964's Avatar
Rewards Points: 166
Thanks for replies. I know there had to be something a long that line. I actually have on around my shop but it old and screw connections are exposed. Just didn't know what they were called
Tags
attic , electrical , lighting , switch
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Pilot Light Switch? dweeter Electrical 3 11-04-2011 08:44 PM
Newbie - fixing a switch and adding a light telechick Electrical 3 09-14-2011 08:59 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
