Attic Light - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 01:43 PM   #16
Originally Posted by hammerlane View Post
So you have only switched power going to the fan. You cannot power a pull chain light with that from the fan location.
EDIT...you can, but in order for the pull chain light to have power, the fan switch would have to be on.
I dont understand. If I cut into the wire to the ceiling fan and then pigtail it back together in a junction box then run my power from that box to power the light why would my ceiling fan switch in my bedroom have to be on?
miguel24932 is offline   Reply With Quote
Old 03-25-2013, 04:10 PM   #17
Rewards Points: 2,516
This is your before setup with power into the switch box, then to the fan.
hammerlane is offline   Reply With Quote
Old 03-25-2013, 04:11 PM   #18
This would be your after setup if you cut into the cable that is leaving the switch to the fan.
The wire in this cable is a switched HOT. Look at the diagram.
Look at the blue junction box, each "black" wire shown in there is only HOT when the switch is on. Do you not see that??
Old 03-25-2013, 04:15 PM   #19
like I said before, you need to grab power from your switch location
Old 03-25-2013, 04:26 PM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 1,458
It depends on when his house was built....
ALL of my lights have power going to them...not the switch....the switch is just the switch leg for the light.
If the OP's is this way, then it's easy.
Old 03-25-2013, 04:53 PM   #21
house was built in 1964.
Old 03-25-2013, 05:00 PM   #22
JOATMON
ddawg16's Avatar
The only way to know is to open it up and check.
Old 03-25-2013, 05:00 PM   #23
I understand that the issue is that the switch controlling the ceiling fan that I want to grab power from has 2 black leads so power is going through the switch obviously and then in the gang box i see 2 others black wires wire nutted together with the switch as well. So, by seeing that I am assuming some other fixtures are getting power from that line in wire going to that switch. Where those other wires lead I don't know. Not about to open up walls.
Old 03-25-2013, 05:01 PM   #24
The poster said in post #13:
Line power comes into the switch. Power goes out to the load.
I interpret that as this:
Old 03-25-2013, 05:27 PM   #25
Ok, so a switch loop your basically eliminating the neutral and using it as a hot wire on the switch? So, if you grab power from the light to feed another light you don't have to keep the first switch in the ON position?
Old 03-25-2013, 06:15 PM   #26
You are not eliminating the neutral. You are just using the white insulated conductor as an ungrounded conductor.
Electricity does not care what color the insulation is on the wire.
But I guess in simpler terms, you are not using the white a s a neutral.
Old 03-25-2013, 06:17 PM   #27
But in your case you do not have constant power at the light. You only have switched power.
Old 03-25-2013, 10:24 PM   #28
I understand but with a switch loop I can tie into the ceiling fan for power and not have to keep its switch ON so the attic light can be on, correct?
Old 03-26-2013, 05:35 AM   #29
Yes if you have constant power into the fan location then you can "tie" into here to power your attic light.
Hope you see the difference in the two diagrams below. The top diagram has constant power at the fan and the bottom diagram only has switched power at the fan
Old 03-26-2013, 07:57 AM   #30
Yes I see that now. Are you into plumbing at all?
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 12:53 PM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 03:23 PM
renovating an attic boltandnuts Electrical 3 04-27-2010 06:06 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
