Attic Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 08:37 AM   #1
attic light
HI,
I want to add a simple attic light and use a nearby ceiling fan for a power source. Obviously I will be able to see the ceiling box from the attic but can I access the wiring from the attic without taking down the fan from the room?
miguel24932 is offline   Reply With Quote
Old 03-25-2013, 08:46 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
Not really.
Old 03-25-2013, 08:48 AM   #3
Rewards Points: 2,516
Originally Posted by miguel24932 View Post
HI,
I say you will have to take the fan down to access the wiring for a run to this attic light. Have you gone up in the attic to see what kind of box there is for the fan?
Will you be adding a switch to control this new attic light or will it be controlled by the switch for the fan?
hammerlane is offline   Reply With Quote
Old 03-25-2013, 08:50 AM   #4
Originally Posted by jbfan View Post
Not really.
I guess this would be correct if he cut into the cable going to the fan and installed a junction box. Provided it is not a switch leg.
Old 03-25-2013, 09:11 AM   #5
see diagram below. Ground wires not shown for ease of drawing.
attic light-power-ceiling-fan-switch-loop.jpg   attic light-power-ceiling-fan-switch-loop-add-attic-lite.jpg
Old 03-25-2013, 09:18 AM   #6
All Im doing is adding a simple pull chain light. By the way when you run a light through a switch, which im not doing, don't you need a line in wire and then a load wire coming out of the switch? How did you do it just using one wire and the neutral as hot?
Old 03-25-2013, 09:26 AM   #7
It is called a switch loop. Electricity does not care what color the insulation on the conductor is.
Did not use one wire, the diagram depicts a cable with 2 conductors(wires) in it.
Old 03-25-2013, 09:30 AM   #8
here is a simple switch loop:
Old 03-25-2013, 09:35 AM   #9
then eliminate the switch for the attic light...see below
Old 03-25-2013, 12:49 PM   #10
So, instead of the incoming power going to the switch you have it going to the light first?
Old 03-25-2013, 12:56 PM   #11
In all the diagrams...yes. WHy do you have the power coming into the switch location?
Old 03-25-2013, 12:58 PM   #12
If I cant access the wiring from the fan through the ceiling box and i just cut the wire in half and then splice back together in a junction box will that work and then I can run my power to my new attic light from that box?
Old 03-25-2013, 01:01 PM   #13
Line power comes into the switch. Power goes out to the load.
Old 03-25-2013, 01:04 PM   #14
So you have only switched power going to the fan. You cannot power a pull chain light with that from the fan location.
EDIT...you can, but in order for the pull chain light to have power, the fan switch would have to be on.
Old 03-25-2013, 01:14 PM   #15
You have to "grab" your power & neutral for the attic light from the fan switch location.
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 12:53 PM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 03:23 PM
renovating an attic boltandnuts Electrical 3 04-27-2010 06:06 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
