Attic Junctions - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 10:06 AM   #1
Rewards Points: 197
Attic junctions
What does the NEC say about junctions in the attic ?
1) Are attic junctions within the code ?
2) Do they need to be in a box rather than hanging free ?
3) Does the junction need to be above the insulation ?
4) What's the maximum # of wires that can be joined together ?
5) Is there a better way to join the wires than twisting them and using a wire nut ?
Thanks, Arky
Arky217 is offline   Reply With Quote
Old 02-12-2012, 10:37 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
1. Yes, allowed as long as the box is accessible.
2. Must be in box with a cover.
3. No but it is not a bad idea.
4. No limit but you must consider the fill based on the box size and the rating of the wire nut.
5. Not really.
Coastal South Carolina
Old 02-12-2012, 10:40 AM   #3
Rewards Points: 12,830
I just use nail on plastic boxes sitting so the top of the box is level with the top of the rafter.
Old 02-13-2012, 02:31 AM   #4
Limited Experience
Write on cover plate with a permanent marker where the wires go. Sure makes it easier 5 years later when tracing things.
raleighthings is offline   Reply With Quote
The Following 2 Users Say Thank You to raleighthings For This Useful Post:
Blondesense (02-13-2012), jammin06 (02-13-2012)
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
