Old 11-18-2012, 03:05 PM   #1
attic insulation and k&T wiring
Hello, I have recently created access to my attic to add insulation. I had to cut a hole in the ceiling in a closet. I was surprised to find 8-9" of blown in cellulose. I want to add another 8" and found that there is k&t wiring covered up by the insulation.
Can I add more insulation evn the the k&t is covered?
thanks
tiki16 is offline   Reply With Quote
Old 11-18-2012, 03:12 PM   #2
Licensed Electrician
k_buz's Avatar
What do you mean by covered? Already covered in insulation or you are going to remove any insulation near the wiring and then cover it?
Location...Location...Location
k_buz is online now   Reply With Quote
Old 11-18-2012, 03:17 PM   #3
joed's Avatar
K&T is an open air system. It is not supposed to be covered in anything.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-18-2012, 03:17 PM   #4
I was going to add additional insulation since it is already covered.
Old 11-18-2012, 03:21 PM   #5
k_buz's Avatar
No, in fact, it is a real fire hazard when it is covered like that. You need to do something about it. Either remove the insulation contacting the wiring, or call an electrician to discuss removing the knob and tube.
Old 11-18-2012, 03:31 PM   #6
That's what I thought. I have no idea how they got it in there. There wasn't any access till I cut the opening.
Old 11-18-2012, 06:14 PM   #7
joed's Avatar
They go through the roof vents to add it.
Tracing Down Old K&T Neutral Wiring AngelArs Electrical 24 09-11-2012 10:00 PM
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 08:56 AM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
Omg! K&t!! tinman73 Electrical 1 05-18-2008 10:31 PM
