Attic Insulate Over Or Under Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 11:25 AM   #1
Attic insulate over or under wires?
Is it advisable to not cover attic wiring with insulation?
I had to go up in the attic of the house. DD#2 wants a ceiling fan, and I wanted to see how the ceiling light box was attached. It was miserable up there. I feel sorry for you guys that have to do that every day in the summer. Anyway, all of the wires are on top of the blown-in insulation. The house was rewired in the 70's but it is plastic covered Romex not the cloth wound wire. The insulation was added by the previous owner in 1989 or 1990. It looks like whoever blew in the insulation pulled the wires above it.
If I were to add more insulation in the attic, should I not cover the wires?
brgmgb is offline   Reply With Quote
Old 06-19-2012, 11:30 AM   #2
Rewards Points: 12,808
It's fine to cover them, but I would air seal the boxes and any holes in the top plates where the wiring and run through them first.
Make sure to not cover up the soffit vents.
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 01:53 PM
Type of Speaker Cables to use in hot attic megablok Electrical 9 02-23-2012 03:14 PM
Wires from attic to spot in the wall jdimuzio Electrical 5 03-21-2011 12:34 PM
routing wires...attic or basement? redline9k Electrical 2 03-07-2011 02:43 PM
Re-routing wires in attic blakstarr Electrical 10 11-24-2008 06:57 PM
