Attic Fan Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 11:18 AM   #1
How can I bypass the thermostat on an attic fan?
JB82 is offline   Reply With Quote
Old 09-01-2012, 11:53 AM   #2
Rewards Points: 1,574
Cut off power to fan circuit.
Open thermostat box. Cut/disconnect two wires leading into thermostat part.
Connect those two wires together with appropriate sized wire nut.
Close thermostat box making sure the wire connections are done inside it.
Restore power; fan should come on unless you've installed a line switch.
bob22 is offline   Reply With Quote
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
