Attic Fan Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 08:01 PM   #1
attic fan thermostat
I disconnected the thermostat figuring it was broken but it is the motor i had to replace and i have to reconnect the thermostat. It has 4 black wires. I assume one black connects to the fan and one connects to the power. The other 2 are connected to what looks like a switch . where do i connect them.
jfrath is offline   Reply With Quote
Old 05-09-2011, 08:11 PM   #2
Electromagician
one black from the thermo and one black from the switch go to power, then the other black from thermo and switch go to the black on the motor. white from motor goes to white from power and ground the thermo case. the switch is wired in parallel with the thermo so you can just press the switch to check the motor if the thermo isn't calling for the fan to be on.
powerfactor is offline   Reply With Quote
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
