Attic fan and skylights on same circuit ok?
Hi folks...
Looking for some advice. I would like to wire three Velux electic opening skylights using a power feed that is shared with my thru-the-roof attic vent fan. As far as I can tell, only the vent fan is on the circuit in question....and that is on a 20 amp cicuitbreaker.....the line goes through a standard switch so that fan can be turned on and off (along with its automatic thermostat/humidistat).......... Does the attic fan NEED to be on its own circuit? I have already run a line from a junction box I installed in the circuit feeding the fan and have run line that is about 15 feet of 14-2 romex to another junction box I want to use for skylights. The skylights (3 of them) come prewired with 20 feet of 14-2 (one of which I will need to replace so that it is 25 feet long)........and say nothing on them besides "must be wired to a 120v 60hz, 60 watt, continuous electrical feed branch circuit with 15amp breaker" Can I change the breaker out to a 15amp and satisfy the fan and skylight requirements? If I run all three skylghts and the attic fan on this one circuit, should I be ok? My theory is that the fan itself shouldnt use too much power aside maybe from startup (its a brand new unit) and the skylights shouldnt either.... Thanks for your advice folks. |
Why is the attic fan on a 20A breaker? How many watts does the fan draw? Are you sure the fan is the only load on that circuit?
If your attic fan is a standard attic fan it doesn't draw much at all. If your skylights draw 60 watts a piece then you should be find putting the skylights and the fan on the same circuit. If you say it's a new attic fan then hopefully the instructions with the specs are somewhere around. |
Just make sure you do change the breaker to a 15 since you're using 14 wire.
Thanks....
I have had the power shut off to that circuit and can find NOTHING else on it.... No info on the new fan....the old one was only 1.9 amp and they appear to be about the same in size, etc. and I cant imagine the skylights draw much amperage. |
Okay, now you know you need a 15A breaker if you've got 14 gauge wire. I have a 30" belt driven industrial whole house fan I can't find any info on the wattage but will guess between 450-600 watts and the electrician tied it into the same circuit that runs my smoke detectors. If they can attach a 1/3rd hp 30" fan into another circuit, I wouldn't see why you couldn't do the same for a simple attic vent fan.
It was a 20amp circuit that runs the fan.....I added the 14-2 line to a junction box.... So I will swap out the breaker for a 15 . Thanks! |
| All times are GMT -4. The time now is 09:37 AM. |
