#1 |
Attic Fan Question
I am a first-timer, and I appreciate being able to ask a question. I have a single speed, 30" attic fan that I use to exit the warm air from the house. I would like to be able to slow it down once the house has cooled off, and am wondering if it can be done with this type fan with a rheostat, and if so, what type. I cannot imagine that a typical dimmer switch would be heavy enough. Thank you.
clauff |
#2 |
Attic Fan Question
I personnally have a two-speed 30" belt drive whole house fan installed in my bilevel home. I also have the automatic shutters on the living side of the opening which open as the air is drawn into the fan.
I can say that I never run it on low speed because so much of the fan's power is needed just to "pull" the shutters open while running. While on low speed, there's not much air flow because of that. (I noticed the difference when I installed my fan and tested it for a couple of days before installing the shutters. Wow, the automatic really drops the air flow) Now, if I had the manual shutters I would be inclined to use the low speed. |
#3 |
It was a dark and stormy
Attic Fan QuestionSome motors require a stiff (low impedance) voltage source and if this is the case for your motor in this application, using a rheostat or a 200w bulb in series with the motor would be out. A Variac, or a 1:1, 120v transformer [capable of handling the power] with multiple taps on the secondary, probably will not damage the motor but to be sure you should e-mail the manu (look on the nameplate) or call and ask to speak to an application engineer. There's a 50-50 chance that they answer you[fear of lawsuits, etc.]. |
#4 |
Electrical Contractor
Attic Fan Question
They make attic exhaust fan thermostats for this application.
When it cools down to a selected temperature it shuts off. |
#5 |
Attic Fan Question |
#6 | |
Attic Fan QuestionQuote:
| Display Modes | |
| Accessable attic & Junction boxes (NEC question) | IvoryRing | Electrical | 7 | 04-10-2013 10:30 AM |
| Powered Attic Fan question | spup345 | Roofing/Siding | 9 | 06-30-2008 09:10 PM |
| Attic Venting/Insulating Question | gregt848 | Building & Construction | 1 | 11-25-2007 03:33 PM |
| attic insulation question | dderolph | Building & Construction | 10 | 11-03-2007 06:21 PM |
| Question about attic moisture | Mastershredder | Roofing/Siding | 3 | 03-19-2007 05:32 PM |
