Old 11-13-2009, 03:17 PM   #1
Attic electric
Going to add a subpanel to walk in attis for my home theater room. What size wire do I need to run up to it from the basement to feed the panel?Going to have electric wall heaters not sure if 110 or 220 yet. Also how many wires would it be ? 3 for 110 and 4 for 220. I will have to run 2 110 circuits up there to get 220 right.
Kurt1968 is offline   Reply With Quote
Old 11-13-2009, 03:29 PM   #2
Xtreme DIY'r
Attic electric
You will need to know the load 1st to determine wire size
Heaters can pull a lot of amps
You would be running 4 wires: 2 hots, neutral & a ground to the panel for a 120/240v panel
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
thermostat and humidity controls for electric attic fans lowlysubaruguy Roofing 2 09-25-2008 08:32 AM
