Attic Cable Run Project. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 11:06 PM   #1
Post
Attic cable run project.
Hello to All!
This is my first time here. I'm happy to be a member!
Anyway, my project is to run an electrical line to the second floor of a two family house to the bedroom via the basement, I chase and through the attic to the other side of the house; then drill down through the floor of the attic into the bedroom and run the line and outlets.
The attic space is a full attic with exposed Ceiling Joists that are too high to be reached without a latter. I was wondering if I could use Romex Wire, NM-B 12/2 for the entire run?
My location is New York. Thank you.
FloatingPoint is offline   Reply With Quote
Old 07-24-2011, 11:23 AM   #2
Licensed electrician
Rewards Points: 1,622
Some areas in NY do not accept NM as a legal wiring method. Check with your building officials.
Old 07-24-2011, 09:13 PM   #3
Okay, thanks.
Burying Coax Cable Master Brian Electrical 4 08-07-2011 02:21 PM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
My project... The Cable Guy Electrical 10 01-02-2011 09:14 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 04:27 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
