Old 08-31-2012, 10:50 AM   #16
E2 Electrician
stickboy1375's Avatar
Attempting to wire central exhaust fan to multiple switches
Originally Posted by ebnub View Post
So in the future if I decide to swap those push button timers where the switches are can I use the neutral wire off the adjacent outlets? If I did this the neutral wire would be coming off a completely different breaker than the fan circuit.
Absolutely not.
Old 08-31-2012, 11:00 AM   #17
E2 Electrician
My next question is, since you are using the fans to create a negative pressure and force fresh air into the dwelling, but at a cost of losing conditioned air, wouldn't a fresh air exchanger be a better route to pursue in the long run of a economics stand point?
Old 08-31-2012, 11:12 AM   #18
" Euro " electrician
frenchelectrican's Avatar
I was thinking the same thing as well.
I belive the fresh air exhcanger can justify the cost and will not loose any heated or cooled air at all.
That should be pretty much norm for new home construction due they make it so airtight.
I have see it couple time in Wisconsin and it will become common over here in France.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
stickboy1375 (08-31-2012)
Old 08-31-2012, 11:31 AM   #19
OK and here's the new diagram:
If I understand your diagram correctly, if any one of your toggle wall switches remains "ON", your fan will always remain on, overiding any and all your timer switches.
I could see this as a "user error" problem if, for example, you have guests who don't know what the fan toggle switch does (since there's no obvious local "feedback"), and leave the swtich in the ON position. You might want to use pilot light (when ON) toggle switch, or a double-pole single-throw switch that also controls the bath light, as a way to remind or ensure the local fan switch is turned off when the bathroom is vacated, and thus releasing control of the circuit back to the timer(s).
sixspeed is offline   Reply With Quote
Add Third Timer Switch to Central Exhaust Fan MaxSteel Electrical 4 11-01-2011 03:08 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
voltage on ground wire - multiple ground problem? Thaiman Electrical 14 04-02-2011 12:49 PM
Multiple switches for a ceiling fan dmr7547 Electrical 10 03-04-2008 04:25 PM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
