Attempting To Rewire Old Electric Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2013, 11:35 PM   #1
attempting to rewire old electric motor
Hi all: This is my first post ,so please bear with me. I am in the process of setting up a machine shop in my garage. I am attempting to rewire a old 1/2 hp GE electric motor on a 1945 circa Bridgeport milling machine. It is currently wired for 230 volts. I opened up the drum switch and found the insulation in extremely poor shape. I removed the cover plate on the motor, and there is a schematic on the back of the plate, but it is barely legable. I can make out that the motor was manufactured for GE by Century Electric. The thing I am confused by is it says the motor can be run at high and low speed, even though the nameplate lists the rpm as 1140. The machine runs, I want to replace the wiring to and from the drum switch, but my question is this. Is this a typo, or can a single phase motor be wired to run at more than 1 speed? If not, its not really a big deal, but if it can,how is it done? It would be nice to have the flexibility as far as machining is concerned. Thank you in advance. Karl
kephilipp is offline   Reply With Quote
Old 11-21-2013, 06:57 AM   #2
I'm not too familiar with these machines, but I'd assume that it was gearing and not a motor speed up or down? If so there are ways to speed up and down a motor, that rating is most likely the max?
QTElectric is offline   Reply With Quote
Old 11-21-2013, 08:12 AM   #3
You are correct, there is a step pulley system on the machine, and spindle speeds are changed by that means. I was wondering if the actual speed of the motor itself could be changed. The schematic on the motor plate seems to indicate a high and low speed circuit in the motor. It appears that the position selected on the drum switch determines which circuit is energized. Currently both circuits are wired on at the same time. I can't ascertain the rpm the motor is running at now. I just don't want to try and wire the motor from the switch and cook the motor. I can make out part of the schematic, but not clearly enough to be comfortable. Thanks for the input. Karl
Old 11-21-2013, 08:39 AM   #4
joed's Avatar
Rewards Points: 12,924
Yes some motors can change speed. There is usually a plate on the motor that shows the wring for the two speeds. What the speed change is doing is changing the motor between two pole to four pole thus doubling or halfing the speed.
Old 11-22-2013, 10:07 PM   #5
Idiot Emeritus
Rewards Points: 1,492
The vast majority of motors that have more than one speed are single voltage. Some are reversible, some are not.
How many wires in the motors terminal box?
If there are 3, then it's most likely single voltage, two speed and not reversible. If 5, then it's single voltage, two speed and reversible.
Most single phase two speed motors are 1140/1725 RPM.
The vast majority or washing machines that have a normal and a delicate setting have two speed motors, almost always 1140/1725.
micromind is offline   Reply With Quote
Old 11-23-2013, 09:23 AM   #6
joed's Avatar
Actually most of the ones I have seen are 1725/3450
Old 11-23-2013, 09:58 AM   #7
Rewards Points: 13,750
Unless this is different then then hundreds of Bridgeport's I've ran and worked on that drum switch is to just switch it from forward, stop and reverse.
Look on the motor it's self and see if there's a metal plate to better ID it.
Old 11-23-2013, 11:33 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You sure it didn't say HIGH/LOW voltage instead? meaning it can be wired at 220 or 110?
The Following User Says Thank You to stickboy1375 For This Useful Post:
micromind (11-23-2013)
Old 11-24-2013, 11:33 PM   #9
Thanks all for all the info. The motor is 230 volts only.Upon closer examination, it appears that the cover plate I removed was not the original one on that motor, as the number of wires on the schematic and in the motor did not match. I wired it back the way it was, and it is working fine now. Apparently, if the motor installed matched the wiring diagram, itindicated it could be wired to run high or low speed, in addition to being reversed as well. Not going to worry about it right now. If I need to vary the motor speed I found a company that makes VFD's for sinle phase motors. I will try to get a decent picture of the wiring diagram and post it. Interesting if nothing else. Thanks. Karl
Condenser Fan Motor stopping after 10-15 minutes, but will restart justplumducky HVAC 22 08-25-2016 04:18 PM
Humming from electric motor freezed up BrandonD Electrical 4 07-02-2013 09:22 AM
Magnetek Century electric motor problem kilgoretrout71 Electrical 9 06-07-2012 06:11 AM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 03:51 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
