Attaching Service Entrance Cable To Vinyl Siding - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2015, 12:06 PM   #1
Rewards Points: 125
Attaching Service Entrance Cable to Vinyl Siding
I am in the process of ordering supplies for my vinyl siding job this spring/summer. I will be siding over my wood siding with housewrap, and the installing the siding. Currently, my electrical service attaches to a weather head at the top of the gable end of my house, then runs down to the meter at the top. Next it runs from the bottom of the meter box into a 90 degree sill plate and into my basement panel. My question concers how I am supposed to re-attach the cabling to the side of the house once the vinyl is on? I don't want to put a bunch of screw holes in the brand new siding. I will add some pictures once I get home from work. Thanks!
chronojosh is online now   Reply With Quote
Old 04-29-2015, 12:17 PM   #2
Rewards Points: 2,576
Ideally it should all be in CONDUIT, attached to the house at the roof edge, and the sill plate.
So no screws needed to attach it, J channel around the meter box, and sided normally thereafter.
ED
de-nagorg is offline   Reply With Quote
Old 04-29-2015, 12:54 PM   #3
Licensed electrician
Rewards Points: 3,650
Even a conduit is going to require conduit straps to secure it.
There is nothing wrong with SE cable.
Look at the mm18 from Arlington.
Old 04-29-2015, 03:11 PM   #4
Rewards Points: 1,165
ED
I agree , put it in conduit . The conduit , straps and screws can be painted to match the siding .
God bless
Wyr
WyrTwister is online now   Reply With Quote
Old 04-29-2015, 03:40 PM   #5
Rewards Points: 125
Here's a pic of the cable coming down to the meter
Old 04-29-2015, 03:41 PM   #6
Rewards Points: 125
Here's the service cable attached to the gable fascia.
Old 04-29-2015, 03:42 PM   #7
Rewards Points: 125
Here's where it enters the house.
Old 04-29-2015, 03:49 PM   #8
Rewards Points: 125
Ignore the window, they are going to be integrated with the housewrap. I also already bought the Arlington mm22 to mount the meter on. I guess the conduit clamps will be fine on the fascia, but they're still what I have to use on the siding itself? Also, how do I handle, as far as flashing and siding, where to cable enters the house?
Old 04-29-2015, 04:48 PM   #9
Rewards Points: 3,264
Two hole straps and long screws. J channel.
This should probably be in a sidelong forum.
I see around here these siders take EVERYTHING off the wall then reattach it. Or j channel everything or just the meter
They pry the meter pan off. Pretty gutsy haveing the screws roll around in alive meter.
For me I would temp support this an that and remove everything from the wall then re attach.
Maybe you could get an electrician by you to keep it safe. Take it away from the house then re support it.
That or I channel and screwing around.
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
chronojosh (06-07-2015)
Old 06-07-2015, 11:11 AM   #10
Rewards Points: 125
Yeah. I'm going to call an electrician for it. I already emailed the power company and they told me to call an electrician to come remove it as well.
Old 06-07-2015, 12:12 PM   #11
Be safe .
God bless
Wyr
Old 06-07-2015, 12:55 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 668
That does NOT have to be in conduit. In some places it is required or SOP for conduit, but typically not.
Answers based on the 2011 NEC.
Old 06-07-2015, 12:59 PM   #13
Conduit on the exterior is SOP in my little part of the world . Can not say about the rest of the big wide world .
God bless
Wyr
Old 06-07-2015, 01:43 PM   #14
I really hate when there is J channel alongside the riser. Looks like hall.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Speedy Petey (06-07-2015), stickboy1375 (06-08-2015)
Old 06-07-2015, 02:32 PM   #15
Electron Plumber
Rewards Points: 1,848
Can you maybe put a wrapped PT 2x6 running vertical from the meter and side up to it? Trim it out with J channel. Use 2 hole SE straps spaced evenly and it should look pretty good.
Sill Plate Repair with Vinyl Siding jevchance Carpentry 7 09-12-2014 10:04 AM
My Cable TV Project (Advice Needed) 95PGTTech Electrical 19 08-30-2014 03:59 PM
underground service entrance cable for burial rem1945 Electrical 1 01-19-2012 06:35 PM
service entrance cable type & size Chuck S Electrical 5 01-08-2011 10:14 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
