Attaching PVC Conduit To Stucco - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 01:24 AM   #1
RAP66's Avatar
Attaching PVC Conduit to stucco
Hi there,
I want to run ~15ft of PVC conduit so I can add an additional halogen light for the back yard. I plan on tapping into the existing lamp and making the run to the opposite side of garage. I have all the parts but I need to know how to attach the conduit to a stucco wall.
Rich
RAP66 is offline   Reply With Quote
Old 02-16-2013, 06:31 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
Screws would be an obvious answer.
Are you asking how to screw into stucco? That depends on how thick it is. If it is pretty thick you'll need a hammer drill or a couple of hammer drill bits for a regular drill, and some concrete screws, like Tapcons.
Old 02-16-2013, 06:38 AM   #3
Rewards Points: 13,446
Any reason to not do this from the inside of the garage, sure would look better then exposed conduit.
Old 02-16-2013, 06:52 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What is the stucco attached to? Wood, concrete, foam?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Speedy Petey (02-16-2013)
Old 02-16-2013, 12:13 PM   #5
Rewards Points: 126
I agree and would find a way to do it from inside.
Old 02-16-2013, 12:52 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
I also agree on going inside. If you have the typical California garage that is not finished inside, just pull the existing lamp off...fish new wires back through and run them down to the new location. If you don't plan on finishing the inside of your garage....just use EMT of PVC conduit with THHN wire. If you plan to finish the inside, then drill the studs and run Romex. It will look a whole lot better.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
electures (02-16-2013)
Old 02-16-2013, 03:57 PM   #7
RAP66's Avatar
lots of good points!
The stucco is rougly 1/2 in or so, inside the garage the areas I see looks like tar paper and chicken wire/hardware cloth. I would rung through the inside of the garage but the previous owner partially finished the inside of teh garage and I would have to tear that stuff down to get access. I dont like the idea of having conduit outside either, so maybe I'll rethink this one a bit more before doing anything.
Old 02-16-2013, 04:17 PM   #8
JOATMON
ddawg16's Avatar
Actually, your stucco is going to be more like 1" thick. Your garage sounds just like mine did.
Can you post pics?
I'm thinking you have some 'attic' space to work with.
Old 02-16-2013, 06:27 PM   #9
RAP66's Avatar
Thanks DDawg,
LOL! and yep, I think 1" is more likely, I was only guessing for the post.
I couldnt reply back to your pm, not enough posts to be allowed to send pm's.
I'll get some pics up tomorrow: Outside & inside correct?
Attaching Lean-To to Stucco Home TipsyMcStagger Building & Construction 4 10-03-2012 10:52 AM
Attaching 2" Schedule PVC conduit to the bottom of a mobile home rrolleston Electrical 2 01-25-2012 07:54 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Attaching Leger Board To Stucco John Charles Building & Construction 0 12-28-2009 01:46 PM
