Attaching Plastic Junction Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 10:09 AM   #1
Attaching plastic junction boxes
Is it permissible (by NEC) to attach a plastic junction box by running a screw through the bottom of the inside of the box into a cleat below (between two studs)?
Thank you kindly.
Jim_D is offline   Reply With Quote
Old 09-15-2011, 10:23 AM   #2
Code05's Avatar
Rewards Points: 1,104
Technically no. What are you trying to do?
Code05 is offline   Reply With Quote
Old 09-15-2011, 10:28 AM   #3
eek
The horizontal variants of either of these might serve you well if you installed them vertically (if I understand how you're trying to mount it)
http://www.aifittings.com/catalog/fa...-outlet-boxes/
http://www.smartboxinc.com/electrical_boxes.php#1
It's probably simpler just to use an old work box
eek is offline   Reply With Quote
The Following User Says Thank You to eek For This Useful Post:
Jim_D (09-15-2011)
Old 09-15-2011, 12:01 PM   #4
I need to precisely position several j-boxes between studs. I could frame a horizontal 2x4 both above and below where I need the box, then put a little cripple vertically between those two at precisely the right location and attach the j-box to that.
On the other hand, if I could screw through the bottom of a box, I could simply put a horizontal 2x4 between the studs at the exact height and attach the box anywhere I wanted.
The boxes "eek" refers to look perfect.
Old 09-15-2011, 12:05 PM   #5
Problem is, it's new work and the "wall", once it's done will be 1.75 inches thick. Sheetrock plus granite back-splash.
Those boxes you refer to are PERFECT. In fact, I could run a 2x4 horizontally between the studs and attach a horizontal box vertically or a vertical box horizontally to get EXACTLY what I need. I am trying to find where to buy them in North Carolina.
Old 09-15-2011, 12:14 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Carlon makes boxes that have a plate on the side to be screwed into a stud, and they make adjustable ones like that also.
jbfan is online now   Reply With Quote
Old 09-15-2011, 12:17 PM   #7
jbfan,
Those are great little boxes. Problem is, I don't have a stud to attach them to. I only have a horizontal member and want to mount the box vertically.
Thoughts?
Old 09-15-2011, 12:23 PM   #8
jbfan's Avatar
Rewards Points: 252
Gotha!
How many do you need and how soon.
I have a few that I may never use.
Old 09-15-2011, 02:30 PM   #9
Gotha!
Prolly 8 or 10 by the time I count them all up.
Old 09-15-2011, 02:53 PM   #10
jbfan's Avatar
Rewards Points: 252
I know I don't have that many.
I would put in a 1900 metal box, with a 1.75" mud ring.
Here's one a little over the top, but kinda neat.
http://gw.vtrenz.net/?O3B8KRAL1H
Old 09-15-2011, 03:03 PM   #11
Is that cool!
Tags
junction box , plastic box , screw
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Can you snake plastic pipes? rosemonster Plumbing 10 01-17-2011 08:09 AM
plastic or metal boxes for outlet wiring? yummy mummy Building & Construction 9 12-31-2006 02:37 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 06:54 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
