Attaching Ground Wire In This Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 05:58 PM   #16
Rewards Points: 452
Originally Posted by Jim Port View Post
A metal box does not mean it is grounded. The wiring method needs to have a ground before the box is grounded. Otherwise is is just floating.
is there an easy way to check for ground?
A while ago, I opened up one of the light switches in a hallway, and there was a ground wire coiled up near the knockout connector.
pman6 is offline   Reply With Quote
Old 05-02-2013, 08:41 PM   #17
Electrical Contractor
kbsparky's Avatar
Originally Posted by pman6 View Post
I attached another close up pic of inside the box.
it's not square, but it's deep and has side knock outs.
House was built in 1966, and all the boxes are metal, so I think they should be grounded.
Looks like an octagon box now. Is there an adapter ring on the top, or is it one piece with the box?
-KB
Old 05-03-2013, 01:24 AM   #18
Rewards Points: 452
not sure. why do you ask?
it looks like one piece. but i'll have to break the drywall around it to be sure
Old 06-24-2013, 08:26 PM   #19
Rewards Points: 452
update.
I got the bath exhaust fan wired to this light box with 12-2 romex, and of course there is the extra ground wire hanging there.
I don't think this box is grounded. Back in the 60's, maybe the vanity lights were never grounded. The light switch controlling the light certainly has no ground wire. On the other hand, the sink outlet is armored cable, so I have no idea if the whole house was wired with armored cable.
Anyhow, I just shoved the new ground wire back in the box. Didn't screw it to anything.
Is there any big risk leaving the bath exhaust fan ungrounded?
Old 06-24-2013, 08:41 PM   #20
Rewards Points: 282
which is more likely?
A. That the hundreds of millions of miles of green/bare copper that has been run as part of the electrical code for grounding since 1962 is really not needed.
OR
B. that your install is a problem.
update.
jcrack_corn is offline   Reply With Quote
Old 06-24-2013, 11:35 PM   #21
Rewards Points: 1,192
Can a ground wire be attached to any screw in this box? like the big screw in the middle?
I'm wondering because new vanity lights have their own ground wires, and it doesn't look like there's anything to screw it to.
Make sure you have a ground wire first!
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Kyle_in_rure (06-25-2013)
Old 06-28-2013, 04:02 PM   #22
Rewards Points: 452
what if there isn't? fire?
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 02:29 AM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 08:08 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
