Attaching Ground Wire In This Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 06:54 AM   #1
Rewards Points: 452
attaching ground wire in this box
Can a ground wire be attached to any screw in this box? like the big screw in the middle?
I'm wondering because new vanity lights have their own ground wires, and it doesn't look like there's anything to screw it to.
attaching ground wire in this box-img108.jpg   attaching ground wire in this box-img107.jpg
pman6 is offline   Reply With Quote
Old 05-02-2013, 06:56 AM   #2
Licensed electrician
Rewards Points: 1,266
Screws used for ground wires shall not be used for any other purpose. You could drill and tap the box for a 10-32 machine screw. Unless that box is very old it is probably already tapped.
Old 05-02-2013, 07:53 AM   #3
Rewards Points: 730
That sure looks like a pancake box and I don't see a connector for the cable. It looks like all four 1/2 knockouts in the back of the box are intact and their should not be knockouts in the sides of a round box.
Mark
busman is offline   Reply With Quote
Old 05-02-2013, 08:00 AM   #4
I thought it looked like a 4 square with a round plaster ring. Never seen a pancake without a straight edged side.
Old 05-02-2013, 08:02 AM   #5
Electrical Contractor
kbsparky's Avatar
It looks like a 1900 box with a round plaster ring. Some of the rear knockouts are partially hidden, making me think this is not a pancake type box. There is additional room inside.
Drill and tap a threaded hole for a green screw is one way to attach a grounding pigtail for the fixture ground wires. I seem to recall this same photo in another thread about grounding ... <checking> ... ahh here it is.
-KB
Old 05-02-2013, 08:09 AM   #6
Rewards Points: 730
I've seen plenty of fully round pancake boxes. However, you are probably right that this is a 1900 box, but I've never seen one mounted to a bar hanger before.
Mark
Old 05-02-2013, 09:40 AM   #7
JW
mm11's Avatar
Rewards Points: 596
Use a grounding clip instead. If the fixture grounding conductor is too small, take a piece of #14, install under the clip to make a ground tail, and splice to the fixture wire to the ground tail.
mm11 is online now   Reply With Quote
Old 05-02-2013, 09:45 AM   #8
The ground clip only works properly on a straight edge. The one shown is domed.
Old 05-02-2013, 10:51 AM   #9
JW
mm11's Avatar
Rewards Points: 596
What about installing the ground clip close to the tapped holes on the mudring?
Old 05-02-2013, 10:54 AM   #10
I don't think there is enough flat area to get the proper contact area.
Old 05-02-2013, 11:33 AM   #11
Rewards Points: 730
If the box really has ground continuity, then drilling and tapping a 10/32 hole is the easy and correct way to go.
Mark
Old 05-02-2013, 01:11 PM   #12
Rewards Points: 744
Mark
yeah..is the box even itself grounded?
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Willie T (05-02-2013)
Old 05-02-2013, 01:13 PM   #13
JW
mm11's Avatar
Rewards Points: 596
Mark
Tapping a hole is certainly the best method, but using a grounding clip is also correct. It meets the requirements of 250.8, when listed and installed per specs.
Looks to me like a grounding clip might work for the OP, but it's hard to say without actually trying myself. Just giving another option.
If it was me, I'd tap the box. Much better connection.
Old 05-02-2013, 06:26 PM   #14
Rewards Points: 452
I attached another close up pic of inside the box.
it's not square, but it's deep and has side knock outs.
House was built in 1966, and all the boxes are metal, so I think they should be grounded.
Old 05-02-2013, 06:33 PM   #15
A metal box does not mean it is grounded. The wiring method needs to have a ground before the box is grounded. Otherwise is is just floating.
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
