-   -   attaching ground wire in this box (http://www.diychatroom.com/f18/attaching-ground-wire-box-178572/)
pman6 05-02-2013 06:54 AM
2 Attachment(s)
Can a ground wire be attached to any screw in this box? like the big screw in the middle?
I'm wondering because new vanity lights have their own ground wires, and it doesn't look like there's anything to screw it to.
Jim Port 05-02-2013 06:56 AM
Screws used for ground wires shall not be used for any other purpose. You could drill and tap the box for a 10-32 machine screw. Unless that box is very old it is probably already tapped.
busman 05-02-2013 07:53 AM
That sure looks like a pancake box and I don't see a connector for the cable. It looks like all four 1/2 knockouts in the back of the box are intact and their should not be knockouts in the sides of a round box.
Mark
Jim Port 05-02-2013 08:00 AM
I thought it looked like a 4 square with a round plaster ring. Never seen a pancake without a straight edged side.
kbsparky 05-02-2013 08:02 AM
It looks like a 1900 box with a round plaster ring. Some of the rear knockouts are partially hidden, making me think this is not a pancake type box. There is additional room inside.
Drill and tap a threaded hole for a green screw is one way to attach a grounding pigtail for the fixture ground wires. I seem to recall this same photo in another thread about grounding ... <checking> ... ahh here it is.
busman 05-02-2013 08:09 AM
I've seen plenty of fully round pancake boxes. However, you are probably right that this is a 1900 box, but I've never seen one mounted to a bar hanger before.
Mark
mm11 05-02-2013 09:40 AM
Use a grounding clip instead. If the fixture grounding conductor is too small, take a piece of #14, install under the clip to make a ground tail, and splice to the fixture wire to the ground tail.
http://0101.nccdn.net/1_5/33d/308/1e...7863595939.jpg
Jim Port 05-02-2013 09:45 AM
The ground clip only works properly on a straight edge. The one shown is domed.
mm11 05-02-2013 10:51 AM
What about installing the ground clip close to the tapped holes on the mudring?
Jim Port 05-02-2013 10:54 AM
I don't think there is enough flat area to get the proper contact area.
busman 05-02-2013 11:33 AM
If the box really has ground continuity, then drilling and tapping a 10/32 hole is the easy and correct way to go.
Mark
Seattle2k 05-02-2013 01:11 PM
Mark
yeah..is the box even itself grounded?
mm11 05-02-2013 01:13 PM
Mark
Tapping a hole is certainly the best method, but using a grounding clip is also correct. It meets the requirements of 250.8, when listed and installed per specs.
Looks to me like a grounding clip might work for the OP, but it's hard to say without actually trying myself. Just giving another option.
If it was me, I'd tap the box. Much better connection.
pman6 05-02-2013 06:26 PM
I attached another close up pic of inside the box.
it's not square, but it's deep and has side knock outs.
House was built in 1966, and all the boxes are metal, so I think they should be grounded.
Jim Port 05-02-2013 06:33 PM
A metal box does not mean it is grounded. The wiring method needs to have a ground before the box is grounded. Otherwise is is just floating.
