-   -   Attaching 2" Schedule PVC conduit to the bottom of a mobile home (http://www.diychatroom.com/f18/attaching-2-schedule-pvc-conduit-bottom-mobile-home-131401/)
rrolleston 01-25-2012 07:43 PM
I am going to be running some conduit under my mobile home about 50 feet. And I was wondering if anyone has done this before and some some input or pictures. I plan to run it from inside my garage underground about ten feet two feet underground with expansion couplings then It's just stacked brick around the home so I can remove them maybe cement around the conduit got about 50 feet up through an old dryer vent hole in the floor to a 200 amp panel I may be able to get some pictures tomorrow. Will just have to seal hole around the conduit after. Going to run dryer vend through the outside wall.
I think there is some steel cross members down there that can lay the conduit on and somehow fix it so it won't move.
jbfan 01-25-2012 07:57 PM
Beam clamps and mineralac (spelling) straps.
rrolleston 01-25-2012 08:54 PM
Is there a certain size beam clamp that you suggest?
