Attached Garage Wiring Code - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 11:17 AM   #16
joed's Avatar
Rewards Points: 11,624
Originally Posted by joed View Post
Up until 2008 code version three wire feeds were permitted. If your region is not on 2008 code cycle then it is still permitted.
The title of this thread is deceiving. An ATTACHED garage does need a four wire feed. This is however NOT an attached garage. It is 5 feet from the house.
Old 01-02-2011, 08:24 PM   #17
But he does plan on making it an attached garage
So that brings up another question (to me) once it is attached
That then makes the new garage & house one structure
And he is feeding each from the pole to their own panel
Is that OK ?
Old 01-02-2011, 09:02 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Is that OK ?
by code, it can be installed as such but an inspector might balk at it. I believe it shouldn't be done. It lends itself to a lot of safety issues.
Old 01-03-2011, 11:50 AM   #19
In Pa they prefer a 4 wire feed. They do allow a 3 wire feed if 2 8' ground rods are installed. It depends on your area and local codes. In your situation 2 8' rods would need to be installed at the garage for the sub panel.
Rob's Electric is offline   Reply With Quote
correct garage subpanel wiring lawsklsux Electrical 14 11-14-2010 11:54 PM
Exposed wiring - would this be Code? globus999 Electrical 3 09-14-2010 07:07 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 07:47 PM
Wiring Detached Garage for 220v welder 8N1949 Electrical 2 03-11-2010 09:47 AM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 08:58 AM
