Attach #4 Copper To Neutral/ Ground Lug - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 02:28 PM   #1
Attach #4 Copper to Neutral/ Ground Lug
I am putting a subpanel in the garage that is 100 amps. I have the conduit ran and the wire pulled and need some advice on how to proceed.
I have an old Bulldog Pushmatic 200 amp load center that works well. You can see from the picture that the neutral/ ground bar is about full and even if it were not it will not take a #4 copper conductor in the bar. Another problem is that this box is 60 years old and parts are scarce.
The only place that conductors that large would fit is where the outside bare ground tied to the ground bar and water pipe ground are tied to the main neutral cable and there is not enough room in the lug to put it in there. Even if there was room I do not know if that is permissable.
Someone suggested that I use a split bolt connector and just bond the neutral from the subpanel to the bare ground that is tied to the outside ground bar and tie the ground from the subpanel to the bare ground that ties to the copper water pipe. That just doesn't seem safe. However, I do not see what it would matter since they are all bonded at that point. I just have a worry about current somehow flowing through the copper water pipes and someone getting electrocuted.
I would appreciate any suggestions. This is just temporary until spring since we just bought this old place and I just need to get some tools running in the garage. In the spring I am having the utility company pull a 400 amp feed and put a transformer on the back hill.
Until then I just need something that I know is safe to get the juice flowing.
Thanks, Steve
Sierevello is offline   Reply With Quote
Old 01-28-2011, 03:09 PM   #2
Master Electrician
Rewards Points: 3,818
deleted
brric is offline   Reply With Quote
Old 01-28-2011, 06:10 PM   #3
Rewards Points: 1,494
You could install another bus bar (terminal strip) for ground wires in the panel.
(Scrape the paint off the spot where you can install it) and follow the instructions that come with the bus bar sold separately.
The plumbing must be bonded to the panel ground anyway. So, assuming the grounding electrode system is complete there won't be electricity going through your water pipes in a dangerous manner.
Old 01-29-2011, 01:04 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
you will need to get some lugs or double lugs and bolt them in the box if you don't currently have spaces for your #4. Say for example remove the lugs that the mains are landed on and replace with doubles. See an electrical supply house.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Ground and Neutral in Panel bvbellomo Electrical 21 07-17-2010 09:53 AM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Ground wires on neutral bus jprince Electrical 6 05-25-2009 08:49 AM
Electrical connections TazinCR Electrical 11 01-07-2009 07:10 PM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
