Assistance With Wiring Diagram/circuits - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 10:07 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by k_buz View Post
Generally, I do not see recessed lighting and fans in the same room period. I'm not saying that it isn't done, but I don't see it.
With Hugger fans they are not too bad but downrod'ed verison that kinda iffy depending on type of fan style so soon I heard recessed luminaires I useally keep them away further especally if you have stepped ceiling. you know how it goes with stepped ceilings done with that.
They are worst when someone use the open trim with BR30 bulbs that useally a afterthought flicker or shadow show up like that so I useally use the baffled verison that useally do the trick.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
k_buz (12-27-2012)
Old 12-28-2012, 06:43 AM   #17
Lic Elect/Inspector/CPO
I have installed many fan and recessed lghts in great rooms. The key is to use correct downrod and make sure the fan blades are far enough away from the reessed light.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
frenchelectrican (12-28-2012)
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Smoke, sparks and pops from ceiling fan - need assistance on proper wiring zstopa Electrical 16 07-17-2011 08:26 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 10:42 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
