Asbestos Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 03:15 PM   #1
Rewards Points: 169
Asbestos wire?
Wondering if anyone has been wire insulation like this before. Could it be insulated with asbestos?
RCGA is offline   Reply With Quote
Old 04-22-2013, 03:23 PM   #2
Rewards Points: 528
Yes I have seen and no there is no asbestos on it. Early 50's wire I think.
framer52 is offline   Reply With Quote
Old 04-22-2013, 03:24 PM   #3
Rewards Points: 169
Hmmm, is that so?
House was built in 1967 as far as I know
Old 04-22-2013, 05:11 PM   #4
Rewards Points: 1,294
I have a house full of it. Built 1959. No asbestos as far as I know.
danpik is offline   Reply With Quote
Old 04-22-2013, 07:06 PM   #5
Civil Engineer
Rewards Points: 4,514
I too have a house that was built in 1959 with that style of insulation. Could it have asbestos in the insulation? Of course, there were tens of thousands of products produced with asbestos in them. The topic of "Does X have asbestos in it" has been discussed repeatedly on this forum over the past few years, do a search if you care to. The only way to tell if X contains asbestos is to have it professionally tested by a qualified laboratory.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
PaliBob (04-24-2013)
Old 04-22-2013, 07:13 PM   #6
Rewards Points: 712
If that old rag wiring had Asbestos in it, every electrician on the planet would already be dead. The only hazard from that old pitch impregnated cloth (it's sheathing, not insulation) is having black hands for a few days.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
stickboy1375 (04-22-2013)
Old 04-22-2013, 07:32 PM   #7
I had a house that was built around 1965 and it was full of that type wiring. it is ok till it gets brittle and you try to work with it, it just crumbles.
merle is offline   Reply With Quote
Old 04-23-2013, 11:36 AM   #8
Rewards Points: 307
Asbestos danger is way overrated anyway, but still, that cable probably DOES have some trace of the stuff. It was used in everything back then, even diapers (OK, maybe not, but you get the idea).
However, even if it does contain asbestos, it poses no danger at all unless it is manipulated. The covering is an encapsulation due to paint or other coating applied. The friable fibers are contained.
If you want to move it around, simply wear a face mask, glasses and gloves, clean up the work area when you are finished, vacuum your clothes before laundering and take a shower. You will not die.
al_smelter is offline   Reply With Quote
The Following 2 Users Say Thank You to al_smelter For This Useful Post:
Speedy Petey (04-23-2013), stickboy1375 (04-23-2013)
Old 04-23-2013, 11:39 AM   #9
Rewards Points: 169
Well my biggest concern with it is with the resale of the home. But I have no idea if home inspections are keen on that sort of thing.
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
