Article 358.10 (B) - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 09:58 AM   #1
Rewards Points: 236
Article 358.10 (B)
i am looking at my city codes, and it says that is "Deleted in its entirety".
what is it, and what does that mean ?
thanx
Fix'n it is offline   Reply With Quote
Old 09-14-2013, 10:13 AM   #2
Licensed electrician
Rewards Points: 1,622
It means this section does not apply.
358.10 Uses Permitted.
(A) Exposed and Concealed. The use of EMT shall be
permitted for both exposed and concealed work.
(B) Corrosion Protection. Ferrous or nonferrous EMT, elbows,
couplings, and fittings shall be permitted to be installed
in concrete, in direct contact with the earth, or in areas
subject to severe corrosive influences where protected by corrosion
protection and approved as suitable for the condition.
Trying to find a great long article on home maintenance wildturkey101 General DIY Discussions 8 07-12-2011 12:34 AM
Demand Load Calculations sirsparksalot Electrical 6 05-10-2011 05:42 PM
Toolbox article jmar Carpentry 0 02-02-2011 09:22 AM
article regarding placing a deck on a roof Grumpy Roofing/Siding 1 09-18-2009 11:10 PM
