Armored Cable Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 07:20 AM   #1
Armored Cable replacement
First time home buyer here, removed a piece of drywall that exposed romex going in front of the metal junction box where the outlet goes. Everything running through junction box is armored cable, for the kitchen outlets and the Refrigerator, microwave and a few other things all on the same circuit including the lights.
Figured I'd run new 12/2 romex to the Fridge, (fridge non gfci dedicated 20 amp line) and the counter space run 20amp gfci outlet for 3 outlets. Gfci first outlet and the other 2 ran off that outlet to protect the 2 others as well. Ran the lines through holes drilled in the floor joists to panel. Correct?
Armored cable is spliced in the walls and attic, with no bonding of the armor, for a grounding purpose. Is this safe? Should it be replaced, or should I electrical tape it so it stays more secure and let it be? It is cloth armored cable. House is from 50s
kmk7110 is offline   Reply With Quote
Old 09-03-2011, 07:55 AM   #2
Also would there be any way to bond the 2 armored cables together to get the desired effect of a ground?
Old 09-03-2011, 09:02 AM   #3
Rewards Points: 1,192
Proper metal box.
bobelectric is offline   Reply With Quote
Old 09-03-2011, 12:11 PM   #4
Rewards Points: 160
Your wiring run sounds correct. The fridge will be fine with a 15amp circuit but if you don't have any 14/2, the 12/2 is fine.
Get a metal j box with clamps. Armored cable will be grounded as it comes in the box and leaves through the box itself. This is also the proper and safe way to cover the splices.
Remember though code says the box has to be accessible. You'll need to put a blank cover over the box and you can't cover it over with drywall.
You also might want to check the splices and redo them properly if necessary (twist connectors secured with electrical tape).
matt151617 is offline   Reply With Quote
Old 09-03-2011, 05:02 PM   #5
In canada we are allowed only 2 20 amp receptacles for counter plughs
Olsy is offline   Reply With Quote
Old 09-03-2011, 05:09 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You MUST re-do the splices if they are in free air with no box. Without question.
Also, do not tape up wire nuts. There is absolutely NO reason for it.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (09-03-2011)
Old 09-03-2011, 05:30 PM   #7
He's from Wisconsin so it really doesn't matter. And you're wrong as well.
FYI:
26-722 (b) - paraphrase
at least 2 branch circuits shall be provided for receptacles (15A or 20A t-slot) installed for kitchen counters in dwelling units
(i) no more than 2 receptacles on a branch circuit
(ii) no other outlets connected to these circuits
CheapCharlie is online now   Reply With Quote
Old 09-03-2011, 06:28 PM   #8
Rewards Points: 160
Really? The books I've read always said to. Provides an extra level of security in case the twist connector somehow came loose. I have found a splice before that probably never had grabbed onto the wires, but it stayed in place by the electrical tape.
Old 09-03-2011, 06:39 PM   #9
If that's true, it wasn't done properly in the first place. There is no need for tape on twist ons......ever
Old 09-03-2011, 07:09 PM   #10
It is ABSOLUTELY no "safer" with the tape. If the nut is being held on by tape it was not installed right in the first place and the tape is only keeping a lose wirenut from falling off a bad splice.
I dare say 85% of what is in DIY books is not correct and most of it is not common professional practice. Why do you think so many of them have been recalled?
Code05 (09-03-2011)
Old 09-03-2011, 08:37 PM   #11
Code05's Avatar
Rewards Points: 1,104
FYI:
Curious. Why only 2 receptacles on a circuit for a kitchen counter?
Code05 is offline   Reply With Quote
Old 09-03-2011, 08:42 PM   #12
Just for convenience. So you're not tripping breakers when you're running a kitchenaid, 1000W hot plate, toaster....etc.
Burying Coax Cable Master Brian Electrical 4 08-07-2011 03:21 PM
crispy cable! Why wouldn't a breaker trip? morganhammer Electrical 4 04-05-2011 12:33 PM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
How to work with armored cable? Red Squirrel Electrical 11 09-22-2009 12:27 PM
armored cable tomfag Electrical 25 10-30-2008 09:24 AM
