Armored Cable Inside Closet? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 10:47 AM   #1
armored cable inside closet?
I need to run a new line form the basement to the attic. Is it acceptable to run 14/2 armored MC cable through the back corner of a utility closet, out ot reach?
205bhamjim is offline   Reply With Quote
Old 02-27-2010, 11:41 AM   #2
Electrician
Rewards Points: 802
That is fine, just make sure you clip it enough for it doesn't flop around. This usually means putting them closer together then what the code tells you to, which is 5 feet in Canada.
darren is offline   Reply With Quote
Old 02-27-2010, 11:50 AM   #3
yeah i've for the clips 2 ft apart, so should be good, thanks, JC, Birmingham, AL
insulate inside basement closet? qchawkfan Building & Construction 2 01-08-2010 09:20 AM
Too much NM cable sheath inside j-box? deko Electrical 24 11-11-2009 03:27 PM
Closet question: options and wiring diagram? schnitz411 Electrical 6 10-24-2009 11:45 AM
How to work with armored cable? Red Squirrel Electrical 11 09-22-2009 11:27 AM
Linen Closet Lighting stubits Electrical 24 06-19-2009 11:32 PM
