Armored Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 12:20 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Great visual rgsgww.
Thanks!
Old 10-26-2008, 12:35 PM   #17
armored cable
i appreciate your help. i (my youngest son just bought an older house im trying to help) have a circuit coming from the panel with metal armored cable it served a space heater which the city told us we had to remove.i did i thought i would use that circuit for some basement outlets as joe wants to finish part of the basement ..my question is can i use 3 wire romex from a junction box where the unused circiut ends and run some outlets into the family room and have them be grounded ? or do i need to get more armored cable and metal boxes to have properly ground outlets? thanks
tomfag is offline   Reply With Quote
Old 10-26-2008, 02:28 PM   #18
Electrician
Originally Posted by rgsgww View Post
NO PLASTIC BOXES WITH BX, its a violation aswell.
You can easily just use bonding bushings if you felt the need to use plastic boxes.
The bond jumper is a little wire inside the jacket, I will show you what I mean with these pictures:
Not really sure what your trying to say, but that internal bond wire is only for using the AC as a grounding conductor, it was never ment to be bonded to the box or the device. Just want to make that clear.
chris75 is offline   Reply With Quote
Old 10-26-2008, 04:11 PM   #19
Rewards Points: 2,350
Unless the armored cable has the bond strip in it, you can't extend that circuit. You could always get some romex and take it straight to the panel and eliminate the old cable altogether.
Old 10-26-2008, 05:38 PM   #20
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
I am under the impression that the OP is extending a circuit with no egc I thought that if you extend a circuit you have to upgrade the whole circuit. Please correct me if I am wrong but this is my understanding.
Pudge565 is offline   Reply With Quote
Old 10-26-2008, 06:07 PM   #21
The OP is wondering if the armor of the cable can be used as an EGC. The answer is maybe. It depends on the bonding strip inside the cable, or lack thereof.
Old 10-26-2008, 08:08 PM   #22
I know that, probably should have made my statement clearer.
rgsgww is offline   Reply With Quote
Old 10-26-2008, 09:15 PM   #23
Electrician
I was just making it more clear to some of the DIY folks, thats all.
Old 10-28-2008, 03:39 PM   #24
Pudge565's Avatar
Rewards Points: 150
Also isn't there a max distance to it like 6' if you use that as the grounding path? I am not sure. But my question was I thought that you have to replace that ungrounded stuff with wire with ground not just use the case as the ground. I understand what you are saying I just wanted to clarify what I was trying to say.
Old 10-28-2008, 08:39 PM   #25
6 feet is the limit for flexible conduit as a grounding path. Armored cable, as a factory assembly, and containing the bonding strip, has no limitation on length.
And yes, if it doesn't have a ground and cannot itself be used as a grounding path, then it must be replaced.
Old 10-30-2008, 08:24 AM   #26
Pudge565's Avatar
Rewards Points: 150
Ok thank you for clarifying this for me.
1930s armored cable wiring Lisa_90 Electrical 9 08-01-2008 09:24 AM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 02:15 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-18-2008 11:03 PM
Which type of Armored cable. helpless handyman Electrical 4 12-01-2007 09:04 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
