Armored Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2008, 08:14 PM   #1
armored cable
how do i get grounded outlets going from armored cable (2 wire) to modern romex 3 wire? i ran a circuit off armored cable with romex and my outlets are not grounded n thanks
tomfag is offline   Reply With Quote
Old 10-25-2008, 08:32 PM   #2
Use a tightly secured BX or TMC connector on the panel and receptical box and use a bond jumper from the box to the receptical . The armor will be your ground in that situation .
electro is offline   Reply With Quote
Old 10-25-2008, 08:43 PM   #3
Electrician
This is only true if the BX has a internal bonding strip. Otherwise it can never be used as a ground. Also, just buy self grounding receptacles and forget about the bonding jumper from box to device.
chris75 is offline   Reply With Quote
Old 10-25-2008, 09:00 PM   #4
If your working with bx, it needs to have a small bare aluminum or copper wire inside called a "bonding strip" as chris said. This isn't looked over much, and if it is avoided, can cause more problems than you had before...
REMEMBER, when working with bx, if you replace the bushing inside, you need a new one.
rgsgww is offline   Reply With Quote
Old 10-25-2008, 09:02 PM   #5
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I am just pig tailing my ground... But, FYI, these self-grounding outlets are not as easily found as one would hope. I checked all the regular (no GF) outlets at Mendards and could not find one with the self grounding clip. I also checked all of them at our local hardware, and again none with self-grounding tabs...
They mainly have the P&S brand.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-25-2008, 09:04 PM   #6
Your right about the bonding strip . A bonding jumper would be a better application and is required in some areas .
Old 10-25-2008, 09:13 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
The bonding strip is NOT the ground path. It only allows the armor to be used as a ground.
Speedy Petey is online now   Reply With Quote
Old 10-25-2008, 09:19 PM   #8
Electrician
How do you figure it to be a better application?
Old 10-25-2008, 09:21 PM   #9
Electrician
I really think he knew that, and was agreeing. I think he just dislikes self grounding receptacles.
Old 10-25-2008, 10:03 PM   #10
Actually, I do think you are right.
Old 10-25-2008, 10:29 PM   #11
? This doesn't make sense.
Old 10-25-2008, 11:22 PM   #12
Electrician
Which part? he is answering my post with no quote, it just reads like a run on sentence thats all.
Old 10-26-2008, 12:24 AM   #13
No, I understand it all. I was talking about when he said bond wires are better than self grounding.
Old 10-26-2008, 08:27 AM   #14
armored cable
should i use armored cable and metal boxes to get grounded outlets on my circuit that im extending ? i dont know what to pigtail to and i dont know what a bond jumper means
Old 10-26-2008, 12:18 PM   #15
NO PLASTIC BOXES WITH BX, its a violation aswell, unless you use the proper bushings. Bond jumper is a ground wire connecting to the box, I would use a grounding clip, faster.
The bonding strip is a little wire inside the jacket, I will show you what I mean with these pictures **In one of the pictures it labels it as a "bond wire", its actually the bonding strip.**
armored cable-100_4823.jpg   armored cable-100_4827.jpg   armored cable-100_4828.jpg   armored cable-100_4829.jpg   armored cable-100_4830.jpg
1930s armored cable wiring Lisa_90 Electrical 9 08-01-2008 09:24 AM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 02:15 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-18-2008 11:03 PM
Which type of Armored cable. helpless handyman Electrical 4 12-01-2007 09:04 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
