Armor Clad And Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 08:48 PM   #1
Armor Clad and Romex
I have a house with a 60 amp fuse box panel.
The wiring is armor clad. I am doing a slow remodel. First the bathroom. I need to put in new circuits for gfci and lights and outlets. Can I use 12/2 with ground romex from the fuse panel or do I need to setup a subpanel? I plan on replacing all the wiring with 12/2 with ground as i remodel each room. When all done I will upgrade to 200 amp entrance panel. Any advice would be appreciated. Location Is Elgin, IL. Western suburb of chicago.
pinebear is offline   Reply With Quote
Old 10-06-2009, 09:47 PM   #2
300zx's Avatar
Post
I would change out that 60 amp fuse box.You also need a dedicated curuit for the gfci and a lighting curuit. Lighting cab be 14-2 The gfci needs to be 12-2
300zx is offline   Reply With Quote
Old 10-06-2009, 09:57 PM   #3
Civil Engineer
Rewards Points: 4,854
Best check with the local electrical inspector, there are still parts of the U.S. that require armored (BX) cable.
Old 10-06-2009, 10:52 PM   #4
Yes - and one area is around Chicago
Old 10-06-2009, 11:40 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from what I have just seen, BX (AC) is actually not allowed. Nor is romex allowed. It appears Elgin follows Chicago and requires conduit (EMT or IMC or RMC; no plastic)
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Running Romex Bocolo Electrical 6 02-20-2009 09:58 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
Exposed Romex Questions bakerhouse Electrical 1 05-13-2008 11:15 AM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
