Area Light Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 08:17 PM   #1
seansy59's Avatar
Rewards Points: 258
I'd like to wire this area light to the back of my shed. There is a round weatherproof surface mount J-Box with NM-B cable coming out of it. It is where an existing basic floodlight was.
Without changing the wiring or drilling new holes in the shed. Is there any way to mount and wire this fixture?
seansy59 is offline   Reply With Quote
Old 08-27-2012, 08:42 PM   #2
biggles's Avatar
if the exsisting box has a cover on it just mount that lamp on the cover pull the lamp wire into the box and wire up
The Following User Says Thank You to biggles For This Useful Post:
seansy59 (08-27-2012)
Old 08-28-2012, 12:53 AM   #3
" Euro " electrician
frenchelectrican's Avatar
If you mention to the OP to use the exsting box cover.,, My answer is don't do that due the weight and size of dusk to dawn luminaire can rip them off so use the WP cover with short flexiable conduit and hook it bottom of the luminare and use the proper mounting hardware ( lag bolts or other means ) so with strong storm it will not rip them off.
Merci,
Marc
Old 08-28-2012, 02:19 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No there isn't.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Exterior light and outlet installation barmaley Carpentry 7 12-25-2011 10:28 PM
Did I screw up? .....Under cabinet light installation. Don't want a fire hazard! jws3 Electrical 21 08-31-2009 03:14 AM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Halo Canister Light Installation tvinson9 Electrical 5 12-30-2005 06:34 PM
