Arch Fault Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 09:18 PM   #1
Arch Fault Breaker
our bed room lights went out and we checked the arc fault breaker and it wont stay on. We open up all the electrical outlets there was no evidence of arching and I am lost of what is going on.
aispatero is offline   Reply With Quote
Old 06-01-2011, 09:27 PM   #2
Learning by Doing
Leah Frances's Avatar
What precipitated this condition? Did you change any fixtures? Plug something new/different into an outlet? Hang a picture? Run a window AC unit?
Unplug ABSOLUTELY everything and see what happens.
If you feel comfortable in the breaker box and you have a voltage tester you can swap the AFCI (arc fault) breaker for a regular one and see what happens.
You need to check all Junction Boxes, switches, and outlets.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-01-2011, 10:16 PM   #3
I=E/R
a7ecorsair's Avatar
Arc Fault breakers respond to arcing and overloads but they won't tell you which condition caused the breaker to trip. You need to identify every receptacle, light fixture, and switch that is on this circuit and then start eliminating.
a7ecorsair is offline   Reply With Quote
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Arc Fault Breaker Potomac101 Electrical 4 02-24-2008 07:11 PM
