Old 10-17-2009, 02:22 PM   #1
Arcfault GFCI breaker tripping
I have a brand new Square D QO Arcfault GFCI breaker that kicks when I try to run my jigsaw. My plugin tester shows it is wired OK. Any suggestions?
shogy is offline   Reply With Quote
Old 10-17-2009, 02:31 PM   #2
Xtreme DIY'r
Most likely the Arc fault is false tripping
Does the jigsaw work on a non-AFCI breaker?
Does everything else work on the AFCI circuit?
Old 10-17-2009, 02:40 PM   #3
Jigsaw works fine elsewhere. I only have one other exterior outlet on the circuit with nothing plugged in to it. My plugin tester shows it is also wired correctly. I ahve heard of problems with these new Arcfault breakers kickingtoo easily. Any suggestions? Thanks!
Old 10-17-2009, 03:03 PM   #4
Is it an Arc-Fault or a GFCI? It's not both. For Sq-D, its an xx-AFI or xx-GFI breaker.
Willis
williswires is offline   Reply With Quote
Old 10-17-2009, 03:28 PM   #5
I found the problem. My error. Thanks for your help!
LCD TV tripping GFCI breakers throughout house penleydr Electrical 28 06-19-2011 07:39 AM
Freezer tripping GFCI davidclements Appliances 40 10-15-2010 11:38 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
