-   -   Arcfault GFCI breaker tripping (http://www.diychatroom.com/f18/arcfault-gfci-breaker-tripping-55370/)
shogy 10-17-2009 01:22 PM
I have a brand new Square D QO Arcfault GFCI breaker that kicks when I try to run my jigsaw. My plugin tester shows it is wired OK. Any suggestions?
Scuba_Dave 10-17-2009 01:31 PM
Most likely the Arc fault is false tripping
Does the jigsaw work on a non-AFCI breaker?
Does everything else work on the AFCI circuit?
shogy 10-17-2009 01:40 PM
Jigsaw works fine elsewhere. I only have one other exterior outlet on the circuit with nothing plugged in to it. My plugin tester shows it is also wired correctly. I ahve heard of problems with these new Arcfault breakers kickingtoo easily. Any suggestions? Thanks!
williswires 10-17-2009 02:03 PM
Is it an Arc-Fault or a GFCI? It's not both. For Sq-D, its an xx-AFI or xx-GFI breaker.
shogy 10-17-2009 02:28 PM
I found the problem. My error. Thanks for your help! :)
