Arc Fault On Two Bedrooms - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 03:12 PM   #1
arc fault on two bedrooms
When I wired the 2 bedrooms I initially had two separate circuits going to the junction box from the bedrooms but decided to wire them together at the j box then one black/one neutral to the main panel to the arc fault breaker. Is okay and per code to wire it that way or should I change it.
Thanks for your input
Warchild is offline   Reply With Quote
Old 03-25-2013, 03:14 PM   #2
Rewards Points: 14,312
Sounds good to me.
NJMarine (03-25-2013)
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Arc Fault vs Ground Fault. JetFuelBurner Electrical 3 11-05-2011 02:36 PM
Arc Fault Tripping JLW74403 Electrical 2 07-25-2011 10:21 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
