Arc Fault Light Briefly Lit When Turning Circuit Back On... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 07:54 PM   #16
Rewards Points: 83
Originally Posted by gregzoll View Post
If this is a brand new home, as in just built, the contractor who built it, should be taking care of these issues.
Yes he does. Just looking for opinions.
darthsmozers is offline   Reply With Quote
Old 01-15-2012, 07:58 PM   #17
Rewards Points: 6,652
My opinion is to get the contractor to up hold their end of the deal, if they gave you a policy that they would fix any problems for X amount of months/years. If they didn't, then that is were your peers come in handy here to help you out.
One opinion of myself and a few others is that AFCI breakers have their problems, and not every company that puts their name knows everything about them, even though they are supposed to be placed under stringent tests like EFI, RFI, EMI, etc.
Old 01-15-2012, 07:58 PM   #18
Rewards Points: 756
It's acting normally.
It's tripping like it should and yes you should see the light.
AandPDan is offline   Reply With Quote
The Following 2 Users Say Thank You to AandPDan For This Useful Post:
darthsmozers (01-15-2012), gregzoll (01-15-2012)
Old 01-15-2012, 08:16 PM   #19
Rewards Points: 83
He has been most helpful. Since its Sunday I thought I'd ask on here instead first andbgenalittle education so I knw what I'm talking about
Old 01-15-2012, 08:19 PM   #20
Rewards Points: 83
Ok. Well, thanks.
Hmm I wonder, why if I shut off 3 switches (labeled bedroom 2, bedroom 3, and general lighting) did only the general lighting one show the light after switching back on. Could it be that the other 2 have nothing plugged into them as they are empty bedrooms, while general lighting has numerous hallway lights and a few ceiling fans connected?
Old 01-15-2012, 09:05 PM   #21
Missouri Bound's Avatar
Is this slang, or "text" type or is your keyboard screwed up?
Old 01-15-2012, 09:10 PM   #22
Rewards Points: 756
Test all of these AFCI breakers and see what happens when you reset them.
If you just turn them off it may not show the LED if there is no stored code. You can also clear the codes.
This might help: http://www.sea.siemens.com/us/intern...20Card_new.pdf
Old 01-15-2012, 09:42 PM   #23
Rewards Points: 83
Oops iPad keyboard. Should have said "and get a little education".
The Following User Says Thank You to darthsmozers For This Useful Post:
gregzoll (01-16-2012)
Old 01-16-2012, 06:40 AM   #24
darthsmozers, I turned off the autocorrect on my iPhone, due to it would screw up regularly. Now it is just me doing the screwing up when I type on it, and have to go back and edit when I catch it.
Old 01-16-2012, 08:22 AM   #25
Rewards Points: 83
Ok, I hit test on another one. It too lights up with arc fault temporarily upon switching it back on. Cool. I guess what I have to figure out is if the original switch I played with showed the light because of a legitimate fault or because I was messing around with it. Question: since I turned it off in the first place to work on the fan, could that be the sole reason why it showed the arc light after turning it back on?
Old 01-16-2012, 08:39 AM   #26
Rewards Points: 756
Yes, that's probably why you saw the light.
Someone may have hit test at some point before you turned it off or it could have tripped at some point due to a fault.
You may never know - unless it trips again.
Old 01-16-2012, 10:04 AM   #27
Rewards Points: 83
And I guess I'll know if it trips again because the lights connected to it will not work and I would have to reset the switch right?
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Plan on turning an existing light circuit into 3way? mj876 Electrical 8 08-30-2010 05:55 PM
Can 15 A light switch be used on a 20 A circuit? Mi Feller Electrical 26 07-22-2010 04:42 PM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 09:32 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
