Arc Fault Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 06:02 PM   #1
Rewards Points: 77
Arc fault circuit breakers
I am building a new house in Hennepin County MN. I have a two hundred amp service in the garage with a 100 amp sub-panel for the house.
Am I required to use Arc fault interrupter circuit breakers?
bkvanbek is offline   Reply With Quote
Old 03-19-2011, 07:49 PM   #2
Mad Scientist
Yes. As far as I know, all of Minnesota is on the 2008 NEC and requires AFCI breakers for all living areas.
I know that to be the case in the city of Minneapolis, anyway, but I assume it's statewide.
McSteve is offline   Reply With Quote
Old 03-19-2011, 08:12 PM   #3
Rewards Points: 77
Would that include the 100amp breaker of the sub-panel or just the branch circuits?
Old 03-19-2011, 09:06 PM   #4
Rewards Points: 324
no on the main.just branch ckts.except those required to be gfci.
oleguy74 is offline   Reply With Quote
Old 03-19-2011, 11:07 PM   #5
I=E/R
a7ecorsair's Avatar
MN is on the 2008 NEC. The sub panel is supplying your house so those circuits that supply power to the bedrooms, family rooms, dining rooms, parlors, and such, require AFCI.
a7ecorsair is offline   Reply With Quote
Old 03-21-2011, 07:27 AM   #6
Rewards Points: 77
Thanks for the help. The ARCI breakers are really expensive.
Old 06-10-2011, 12:39 PM   #7
Rewards Points: 77
Because it is a sub panel and the ground and neutral bars are split I can only (practiaclly) put the Arc fault breakers on one side, right?
So none of the kitchen, baths, mech room or outside stuff needs the Arcs?
Replacing circuit breakers with AFCI ozdiy Electrical 25 07-04-2010 09:09 PM
arc fault breakers handifoot Electrical 44 01-31-2009 06:10 PM
Why do baseboard heaters have 2 circuit breakers? mhaucke Electrical 4 07-08-2007 06:10 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 11:56 AM
Circuit Breakers Unregistered Electrical 4 09-13-2004 09:49 AM
