-   -   ARC Fault Breakers tripping after a fan install. (http://www.diychatroom.com/f18/arc-fault-breakers-tripping-after-fan-install-18448/)
jAutumna 03-13-2008 12:00 PM
~ I just wanted to ask if it is possible to switch out an ARC Fault Breaker and replace it w/ a plain Circuit Breaker w/out any real hassle?
-J.
CowboyAndy 03-13-2008 12:11 PM
-J.
That depends...
is it a bedroom?
was your house built after 1999? or, is it work that was done after 1999, as in a compleete remodel or an addition?
Does your code have the arc fault in it? my local area removed the arc fault requirement, as have many areas, but not all.
But more inportant, WHY is it tripping the arc fault? how often?
jAutumna 03-13-2008 06:22 PM
It is a bedroom. I had the home built in 2007. The ARC requirements came out in June of 2005. I don't plan on moving anytime soon, so would switching breakers work?
-J.
Originally Posted by CowboyAndy (Post 107294)
That depends...
is it a bedroom?
was your house built after 1999? or, is it work that was done after 1999, as in a complete remodel or an addition?
But more important, WHY is it tripping the arc fault? how often?
jrclen 03-13-2008 07:35 PM
In this case I would want to know why it is tripping. It might be saving you from a very expensive fire and even loss of life. Just my opinion.
CowboyAndy 03-13-2008 07:36 PM
-J.
Legally, no. They are required by code.
Like I said, you would spend your time better finding out WHY it is tripping it. I have several fans in my house that are on arc fault breakers, and have NEVER tripped. 8 times out of 10, if a breaker is tripping all the time there is a problem with the wiring. 1 out of 10 is a faulty breaker and 1 out of 10 is an overload.
Exactly.
frenchelectrican 03-14-2008 12:49 AM
-J.
Unfortetally no if your state is allready required the AFCI we can not inverted back to normal breaker.
if you have issue with it senice you mention after you install the new fan there is possiblty there is a netural wire touching the ground wire it can trip the AFCI [ they can get pretty picky with it ] only way you can slove it is check the wire connection and make sure there is no other " bare " or uninsluated wire touching any spot at all even a little nick on it can trip them.
if the wire is really good shape no nick of whatever it is [ this fan trip after you turn on the switch ?? { it is a wall switch or remote or pull chain fan switch } ]
let us know first then we may able help ya in the right way.
Merci, Marc
RobertS 03-14-2008 06:13 AM
AFCI BREAKER trips with ceiling fan
According to MIKE HOLT the AFCI breakers don't like some motor circuits. You need to have a qualified/good electrician check out the problem. Tread mill motors have been triping AFCI breakers also. If the electrician finds no problem with the circuit he could pull power from a non AFCI protected circuit for the fan/light and switch. Only the receptacles have to be on an AFCI breaker. This information came from a Licensed/Master Electrician friend of mine, and MIKE HOLT. Square D had a recall on some breakers that didn't work correctly. You could try a new AFCI breaker.
CowboyAndy 03-14-2008 06:16 AM
In the 2008 edition, EVERYTHING has to be arc fault (for a bedroom at least). Lights, smokes, etc.
RobertS 03-14-2008 06:21 AM
Talk to Mike Holt
RobertS 03-14-2008 06:24 AM
I will check again thanks. Either way the fan might not work. Do you have the location for that code.
CowboyAndy 03-14-2008 06:34 AM
210.12(B) Dwelling Units, All 120-volt, single-phase, 15-and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining tooms, living rooms, parlors, libraries, dens, bedrooms, sun rooms, recreation tooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc fault circuit interupter, combination-type, installed to provide protection of the branch circuit.
It encompasses EVERYTHING in the room, not just receps.
RobertS 03-14-2008 06:34 AM
Never mind I found the info. I thought they had a handle on AFCI breakers now. I guess motors, and capacitors still mess with them. I have had Microwaves trip them also. I guess it is the high voltage transformer/capacitor circuit.
CowboyAndy 03-14-2008 06:37 AM
Do you have the article that outlines just the changes to the 08 code? someone posted it here and I found it to be really helpful.
http://tnblnx3.tnb.com/emAlbum/album...2008_lr_bm.pdf
RobertS 03-14-2008 06:48 AM
I have that but I was told it was changed because of so much trouble with false tripping of the breakers. I'm sooooo confused.
