Arc-Fault Breakers & Aluminum - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 07:27 PM   #1
Over the last few years I managed to remove a fair chunk of the Aluminum wiring throughout my home and have pigtailed the rest. I would like (loss minimizing) protection from the remaining aluminum circuits by considering Arc flash breakers for the remaining 7 branches.
Am i being overly paranoid, are my Marette 65 & No-Ox junctions adequate?
Id like professional opinion on my “Breaker” idea and the reliability of pigtailing.
Eric
Eric J is offline   Reply With Quote
Old 06-15-2010, 07:45 PM   #2
Electrician
Rewards Points: 778
if aluminum wireing is installed correctly there is nothing wrong with it. Its when people start messing with it and start useing incorrect devices that you run into problems.
Sounds like you have done the correct steps so you should have nothing to worry about.
darren is offline   Reply With Quote
Old 06-15-2010, 07:47 PM   #3
Licensed electrician
Rewards Points: 1,254
You may not find arc fault breakers available for your panel given its age.
Tags
aluminum wire , arc flash
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 04:22 PM
Replace breakers with "arc fault protected" ones? bassman99 Electrical 20 05-05-2009 02:35 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
