Arc Fault Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 09:02 PM   #1
arc fault breakers
hats the current code inspectors are accepting for arc fault. is it bedrooms and smokes? or also living room and dinning room????
jumajunkie is offline   Reply With Quote
Old 01-17-2012, 09:21 PM   #2
Rewards Points: 264
All depends on what version of the NEC your area is using. Also, your local jurisdiction and/or state may have modified the requirements. Where are you located?
a_lost_shadow is offline   Reply With Quote
Old 01-17-2012, 09:23 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jumajunkie View Post
whats the current code inspectors are accepting for arc fault.
The current code varies by location... so, what is what YOUR inspector looking for?
New and remodeling work? Arc fault everything; except:
furnace, fridge, kitchen lights and all 20 amp GFI protected circuits (Kitchen plugs, Bath, etc...)
Don't forget to use TR devices and have a neutral at the switches too.
Old 01-17-2012, 10:35 PM   #4
it's in long beach California.
Old 01-18-2012, 10:46 AM   #5
Rewards Points: 264
Double check with your permit office to confirm they've adopted the latest California code. If they have, then you basically need combination arc fault breakers on every circuit that doesn't require GFCI protection. Here's an information bulletin from my local permit office in Livermore, Ca.
Oddly, CA adopted the AFCI & TR requirements in the last pass, but left out the neutral at the switch.
Old 01-18-2012, 02:48 PM   #6
Neutral at the switch?
OldRedFord is offline   Reply With Quote
Old 01-18-2012, 03:33 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
2011 code requires a neutral at all switch locations.
Welcome from Newnan!
Old 01-18-2012, 11:25 PM   #8
Msradell's Avatar
Rewards Points: 90
I've read that but wonder what you're supposed to do with it? Just cap it off? Kind of negates the use of switch loops unless you run 14/3 doesn't it.
Msradell is offline   Reply With Quote
Old 01-19-2012, 09:12 AM   #9
MarginallyQualified
Switch legs still get used. What gets eliminated is the feed loop around the attic.
The safety principle is about not having that feed (24/7/365 always hot wire)
tied in at every fixture j-box in the attic under those piles of insulation everyone has now.
It will make troubleshooting simpler too.
But the real reason is about being able to sell the new generation of
switches and sophisticated controls that need a neutral to work.
If you're not building new or in a major remodel... you do nothing.
If you are... then you do it different than in the past.
Old 01-19-2012, 09:38 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 840
jumajunkie....I live in the LA area as well....
If it's old construction....you don't have to install AFCI's But you must have battery powered smoke detectors. If it's a rental and your the landlord....LB may require you to do additional things.
New construction?
AFCI in all bedrooms.
GFI for kitchen counter tops, bathrooms, garages and anywhere you can come in contact with concrete or the ground.
Bathroom...dedicated 20A outlet...
Smoke detectors in each bedroom...but not needed in living rooms
CO detector on each floor where there is a combustion source...if you have a gas dryer, then you have to put a CO detector outside the bedrooms....do a search on exact details of where they are to be placed.
If you go down to the LB building office, they will most likely have a handout that explains all of it.
Old 01-19-2012, 04:47 PM   #11
Post
arc fault breakers
Very informative thread. Thank you.
I'm wiring 2 bedrooms and will use arc fault breakers. My question is do I need 1 for each bedroom, or could one do it for both (all outlets on 1 breaker)?
I'm in northern California.
Thank you.
RanchHand is offline   Reply With Quote
Old 01-19-2012, 04:49 PM   #12
jbfan's Avatar
Rewards Points: 144
Thank you.
Your choice!
Old 01-19-2012, 05:30 PM   #13
MarginallyQualified
When you see their price you'll be tempted to load up the circuit and use as few AFCI breakers as possible. Beware of this or use 12ga wire for 20A circuits.
Old 01-19-2012, 05:41 PM   #14
Yes, they are a bit $$. My inclination is to use 2 circuits with 15A breakers and 12ga romex cable.
Old 01-19-2012, 05:43 PM   #15
jbfan's Avatar
Rewards Points: 144
If you are going to run #12 wire, why would you not install a 20 amp breaker?
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 04:22 PM
Arc Fault Breakers nsidhom Electrical 10 08-20-2011 11:54 PM
Arc fault circuit breakers bkvanbek Electrical 6 06-10-2011 12:39 PM
Replace breakers with "arc fault protected" ones? bassman99 Electrical 20 05-05-2009 02:35 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
