ARC Fault Breaker Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 01:05 PM   #1
ARC Fault breaker tripping
Hello....i found this forum via a google search and I can't quite find an answer to my question through searching the internet so I thought I would post it here...
I have a ARC Fault Breaker that seems to trip every few days (seems like 4 or 5 days) The breaker seems to be connected to my master a few outlets in my master bedroom, the ceiling fan in the master bedroom 1 recessed light in the master bedroom and the smoke alarms in the house. This tripping seems to have been going on for a little over a month and I have never had a problem prior to this....the house was built in 2002. I searched and found that things like lamps...phone charges etc can trip an arc breaker....we only have 1 lamp that is plugged into an outlet that runs on that breaker....I just today unplugged the lamp to see if the breaker will eventually trip. If it still does what could be the problem....is it possible that the ARC breaker is bad? Thanks
zevo is offline   Reply With Quote
Old 09-04-2011, 01:21 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I'd turn off the main breaker and tighten the connections in the panel to start with. It could be as simple as that. But with it doing it every few days there could be any number of reasons.
DM
Old 09-04-2011, 01:49 PM   #3
Rewards Points: 150
I would run a new circuit for the smoke alarms
Sunny B. is offline   Reply With Quote
Old 09-04-2011, 02:00 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
What's the reasoning for a new circuit for smoke alarms?
picflight is offline   Reply With Quote
Old 09-04-2011, 02:10 PM   #5
Rewards Points: 150
Not sure if its code, but its deff something that I would do. Reason being, if there is a fault or overload and the breaker trips, at least the fire alarms will still be on.
Old 09-04-2011, 02:13 PM   #6
There has to be a simple reason for this....never had a problem before....but i haven't a clue...hence why i am here. Im thinking it could possibly be a faulty arc breaker....
Old 09-04-2011, 02:23 PM   #7
the Musigician
That's possible. Those things are expensive though, I'd check all other possibilities first.
DM
Old 09-04-2011, 02:48 PM   #8
Where I am, the code specifically prohibits this -- a dedicated circuit for smoke/co alarms. They must be on a general lighting / receptacle circuit, so that if the breaker trips it becomes immediately obvious.
CuHead is offline   Reply With Quote
Old 09-04-2011, 02:50 PM   #9
Rewards Points: 150
Wow that makes since. I never looked at it that way.
Old 09-04-2011, 02:50 PM   #10
To the OP, you need to check each device--receptacle, switch, fan, smoke alarm, and any splices. Inspect each to make sure connections are tight and no obvious problems. The breaker is expensive so that would be a last resort, to replace without knowing if its actually bad. If you have other AFCI breakers in your panel you could swap a known good one to the circuit to see if the problem is in fact the breaker.
Old 09-04-2011, 02:57 PM   #11
i really don't know anything about electrical...what am I looking at cost wise to have an electrician come in and check things out?
Old 09-04-2011, 03:03 PM   #12
Rewards Points: 6,652
If you are running the vacuum every 4 to 5 days, that can be a possibility. Even though you may plug the vac into another circuit with a afci, it could be that rhis one is more sensitive. Is this circuit part of a MWBC (multi-wire branch circuit)? Also, when thid home was built, were the afci's original, when they designed the home and electrical circuits for it.
Old 09-04-2011, 03:11 PM   #13
yes....everything original....it tripped last night while we were sleeping so i would rule out the vacuum theory.... I don't know the answer to the MWBC question,
sump pump keeps tripping breaker after about 5 minutes of running DanDaMan Electrical 9 04-22-2011 12:32 AM
Breaker Keeps Tripping mxingislife Electrical 33 01-12-2011 11:11 AM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 11:27 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 05:13 PM
