Arc Fault Breaker Loose - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 06:35 PM   #1
I just installed an arc fault breaker in my house. I have a Cutler-Hammer box with type BR115 breakers. I just installed a BR series Arc Fault breaker for Cutler Hammer and it is hanging a quarter inch lower than it should. I have a picture I can send. Can anyone tell me if this is the way that they are supposed to attach to the box?
brendine is offline   Reply With Quote
Old 05-19-2011, 07:45 PM   #2
Rewards Points: 6,652
Post a picture with the cover off and another with it on. If you have to, use a extra lamp or some light to help make the picture clearer if the box is in a dark area.
Old 05-19-2011, 08:34 PM   #3
Here is with the cover off. It looks the same with the cover on. There is a small gap with the top heavy breaker sitting low.
Old 05-19-2011, 09:40 PM   #4
Post a better picture showing the whole box, not a crop shot.
Old 05-19-2011, 11:52 PM   #5
It's more than likely the weight of the breaker weighing down on the bussing. Unless it actually feels loose where it connects to the bussing. GE panels with their "slim" breakers have this problem, breaker slop i believe it's called
D5T_Designs is offline   Reply With Quote
Old 05-20-2011, 06:41 AM   #6
Breaker
That is the best picture to see the drop of the breaker. I just want to make sure that this is the correct breaker (Cutler Hammer AFCI for the BR series). I heard that there are issues with these new breakers, but inspectors tend to be picky.
Old 05-20-2011, 11:38 AM   #7
As long as its a BR type panel, the AFCI BR breaker is fine. As for the issues, I cant say much for cutler hammer, but i do know that some of the early on AFCI breakers had problems which were refined within the last few years. Just dont use the cords to pull any plugs out of the sockets that AFCI is connected to, it will cause the "arc flash" that that breaker is supposed to protect from.
Tags
arc fault
HA! Breaker setup, also a few questions. CoconutPete Electrical 6 05-05-2010 12:26 PM
Loose 20 Amp Breaker aggiesrok Electrical 12 05-09-2009 05:42 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Holy smoking commander breaker drogosandybanks Electrical 13 01-10-2007 02:34 PM
